Why is my brake light on when driving.
Old May 4, 2010 | 09:31 PM
SSZ2891's Avatar
so what could cause my brake light to be on at all times?
Old May 5, 2010 | 06:11 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Why is my brake light on when driving.
Pessure Differential Switch? If so, it's alerting you to a leak in one of the brake circuits. Didn't you have a rotted rear line a while back?
http://auto.howstuffworks.com/auto-p...ter-brake2.htm
JamesC
Old May 5, 2010 | 06:14 AM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
low brake fluid? leaky wheel cylinder?
check your master cylinder, if the back reservoir is low, pull the brake drums and look for fluid
Old May 5, 2010 | 09:49 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
e-brake switch is shorted out.
put the car in run but don't start it and put the e-brake down and see if the light goes out.
Old May 5, 2010 | 02:14 PM
SSZ2891's Avatar
JamesC
yes i had a broken line running up into the rear drivers side wheel up into a flex hose. i fixed that but the light is still on
Old May 5, 2010 | 03:42 PM
JamesC's Avatar
Did you reset the light?
From the manual:
The pressure differential warning switch is designed to constantly compare front and rear brake pressure from the master cylinder and energize the warning light on the dash in the event of a front or rear system failure. The valve and switch are so designed that the switch will latch in the "warning" position once a failure has occurred. The only way the light can be turned off is to repair the failure and apply a pedal force to develop approximately 450 psi line pressure.
JamesC
Old May 10, 2010 | 08:51 PM
GtoRockz's Avatar
Car: 1987 Firebird
Transmission: R4
Axle/Gears: Stock
I had the same problem recently. Went to Advance Auto and purchased a new brake light switch ($10), 10 minutes later it was fixed.
Old May 11, 2010 | 08:55 PM
SSZ2891's Avatar
where is the switch?
Old May 12, 2010 | 06:22 AM
GtoRockz's Avatar
Car: 1987 Firebird
Transmission: R4
Axle/Gears: Stock
It is located just above the brake pedal.
Old May 12, 2010 | 09:06 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
I was gonna say the same thing as it doesnt take much to break the switch
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
stalkier
Aug 21, 2015 01:54 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
