wheels wont spin??
Old May 6, 2010 | 10:19 PM
hardyz13's Avatar
Car: 85 Firbird
Engine: 406
Transmission: 700r4 built
Axle/Gears: 3.42 posi 10 bolt
wheels wont spin??
Ok I just put a 4th gen rearend in my car. When the wheels are off of the car both axles will spin with no resistence, but when I torque the wheel onto the car it takes a great amount of force to make the tire turn. I have no clue what is causing this, I have new pads, rotors, calipers, the parking brake is not pushing the pad onto the rotor. The only conclusion I can come up with is that when I put the wheel on it is pushing the rotor into the back pad, which is not letting it turn. Any other ideas?
97 rear disk with 15 inch wheels
Old May 6, 2010 | 10:21 PM
Blown84Bird's Avatar
Car: 84 firebird, 85 transam
Engine: 350 SBC Or 7.07 Tonys,305stock
Transmission: Big Ugly, 700r4
Axle/Gears: 4th gen rear disk 3.42 lsd,9 bolt
Re: wheels wont spin??
What wheels you have on the car.
Old May 6, 2010 | 10:22 PM
hardyz13's Avatar
Car: 85 Firbird
Engine: 406
there stock 15 inch wheels, but I jacked up the car and don't see where anything would be hitting.
Old May 6, 2010 | 10:24 PM
Rear disk??
Old May 6, 2010 | 10:25 PM
hardyz13's Avatar
Car: 85 Firbird
Engine: 406
Yes
Old May 6, 2010 | 10:28 PM
Probably hitting calipers stock size on 4th Gen is 16
Old May 7, 2010 | 09:11 AM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
That shouldn't matter.. I've got the LT1 rear brake setup on my car and it has plenty of clearance on my stock 15's.
I'd take the wheel off and take some washers on one or two wheel studs and then put the lug nuts on lightly and see if you can find out where its binding.
Old May 7, 2010 | 10:01 AM
If you think the rotor is hitting the backing plate you can put. Some lugs on the rotor ( flat side of nut to rotor ) retest If the axle spins freely then the problem is else where
obeymybird
Exterior Parts for Sale
Nov 3, 2015 08:10 AM
drptop70ss
Oct 4, 2015 09:44 PM
Fionnla
Wheels and Tires
Sep 11, 2015 11:07 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
