93+ Brake fluid reservois on a 3rd gen ?
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Has anyone ever tried to fit a 4th gen brake flui reservoir on a thirdgen master cylinder? Never have liked the stock one, and bleeding is a pain in the *** even with the pressure adapter for this type. Has anyone tried installing a 4th gen reservoir that has the threaded cap rather than a snap on cover?
Will
Will
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 93+ Brake fluid reservois on a 3rd gen ?
you can use the whole master from a 98-02 car, bolts right in, with the nicer reservoir, just have to tweak the little lines to the prop valve a little.
My Man! Just what I wanted to hear!
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
What benefit is there going to a 4th gen booster/master?
Car: 86 Trans Am
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
You can also use one from a 93 to a 98 car also. Just have to change one of the tubing nuts on the front line coming off the master. Very easy to do.
Car: check
Engine: check
Transmission: check
The 4th gen M/C's have a larger or same size piston as the 3rd gen M/C.
The 4th gen M/C have a 1" bore.
Some early 3rd gens also have a 1" bore M/C. These are the ones with rear disc brakes.
The majority of 3rd gens have a 0.945" bore M/C (24 mm).
This means that with a 4th gen M/C about 11% more pedal pressure will be required for the same braking force.
The biggest difference is that the 4th gen M/C are a non-quick take up design. Where the 3rd gen M/C's are a quick take up design.
RBob.
RBob.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
