Brake problem
Old May 19, 2010 | 07:58 AM
RS-Chevy-SS's Avatar
Car: 1989 Chevy Camaro RS
Engine: L30 TBI 5.0L Vortec
Axle/Gears: Stock
Brake problem
Ok car is a 89 RS 5.0 with disc in front and drums in back. Question is i changed the pads about a month ago with duralast semi metallic pad. Didnt turn rotors,now i hear bad squeaking with light to medium pedal pressure. Ideas? And its on both sides
Old May 21, 2010 | 06:52 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Brake problem
how bad are the rotors?
did you properly break in the pads?
could have glazed hte pads and/or rotors
they did come from autozone....
Old May 29, 2010 | 06:57 PM
Axle/Gears: Stock
Re: Brake problem
Did not break in those pads and the rotors were shiny. They did come from autozone.
Update: Just changed out the pads and properly broke them in using the 15-20 near stops from 30 MPH. Squeaking is gone so far, didnt get to turn the shiny rotors as shops are closed today. Do you think that might have fixed it?
Old May 29, 2010 | 08:38 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: Brake problem
we will see.
Old May 29, 2010 | 10:23 PM
Axle/Gears: Stock
Re: Brake problem
we will see.
I just drove it again under normal driving to test and so far its good
ZMWojnar
Brakes
May 12, 2019 10:43 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
overdriv
Aug 20, 2015 03:52 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
