Rear Calipers 87 IROC
Old May 29, 2010 | 08:56 PM
Gary's Avatar
I am having the same problem with my rear disc brakes as everyone else is experiencing. I am thinking of changing the rear calipers, but, cannot get a straight answer from part stores on-line. Some say there is a left and right rear, others say there is only one rear caliper and can be installed on either side. Can somebody shed some light on this for me?
Thanks,
Gary
Old May 29, 2010 | 11:27 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: Rear Calipers 87 IROC
If you have the cast iron calipers, which 87 probably does, then you have a single part number for both sides. One mounts leading the axle and the other mounts trailing the axle. Some 89 and newer cars would have the aluminum calipers that are right/left specific.
Old May 30, 2010 | 12:50 AM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Best bet would be to get some LT1 rear calipers, as they are the same basic caliper that came on the 89+ cars, save for minor cosmetic differences. Then you would need to get the backing plates for your rearend, whether it be a 9 bolt or a 10 bolt. The new brakes will be trailing where, as mentioned before, you have one in front and one behind. I actually have a pair of freshly rebuilt PBR rears, the stock brakes off my 89 IROC, if you're interested. The red paint faded dramatically after only a few hundred miles, but they would clean up very nicely, and they work perfectly
Will
Attached Thumbnails Rear Calipers 87 IROC-brakes2.jpg   Rear Calipers 87 IROC-dscn4277.jpg
Old Jun 9, 2021 | 11:33 AM
87iroz-c's Avatar
Car: 87 Iroc-z
Engine: 350 carburetor
Transmission: 5spd
Will
How much?
Ha nevermind. This post is 10 years old haha
AmpleUnicorn88
Brakes
Jan 2, 2016 12:31 PM
brdofpry85ta
Brakes
Nov 29, 2009 09:27 AM
dv8
Apr 21, 2008 05:33 PM
Zantasmo
Brakes
Oct 11, 2005 11:42 PM
89 Iroc Z
Jan 19, 2002 08:12 AM
