Rear calipers are on the opposite side....WHY!!!
Old Nov 25, 2009 | 12:22 AM
brdofpry85ta's Avatar
Car: 1985 Trans Am
Engine: 6.6 at least
Transmission: T-56 (waiting)
Axle/Gears: 9" w/4.56 & spool (4 now)
Just wondering in anyone can tell me why the rear calipers are on the opposite side.....Does it make for better braking....
I just swapped out my 9-bolt for a 9" and it has drums on it....I want to ditch the drums and up grade the stock disc brakes but not to sure if the factory one will swap over.....
Old Nov 25, 2009 | 12:32 AM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: Rear calipers are on the opposite side....WHY!!!
If my info is correct, for the cast iron calipers, it was a cost saving thing for GM. They didn't have to make separate casting forms for left and right, and used the same part number for each side.
Old Nov 25, 2009 | 05:26 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Those particular disc brakes sucked anyway.
Old Nov 25, 2009 | 06:20 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by brdofpry85ta
JI want to ditch the drums and up grade the stock disc brakes but not to sure if the factory one will swap over.....
The Delco-Moraine calipers have a bad reputaton on TGO, but I'm uncertain if that reputation is truly merited. I ran them for a while and I thought they performed well enough. The time might be ripe for a better selection than the above, however--and there are a number to choose from these days. You might eye the following site for more info:
http://www.flynbye.com/
BTW, the PBR's, in 89+, were the first calipers to both be positioned to the rear of the rotor.
JamesC
Old Nov 25, 2009 | 06:35 PM
Car: 1985 Trans Am
JamesC
....I checked out the link...good info and just might be what im looking for.....
Old Nov 25, 2009 | 06:55 PM
Stephen's Avatar
Car: 87 GTA
JamesC
Mine perform quite well. At idle, they hold the car perfect. Will hold until I go for a powerbrake & roast the back tires. I've locked all 4 brakes from 60mph, when a deer ran out & they never give me any grief, even at inspection time.
All while being behind an Automatic, so the Emergency Brake rarely even gets used, yet never fails at inspection time.
Old Nov 27, 2009 | 12:49 AM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
JamesC
I've autocrossed with them for a little more then 1 season and never had any issues. If I got into the brakes a little to quick, I would actually lock the back and have it slide around on me. It helped rotate the car which was good, but it cost me time and put more wear on the back tires. I plan on doing the C5 front setup this winter but I still don't know what I'm going to do with the rear.
Mike
Old Nov 29, 2009 | 09:27 AM
DeanJ's Avatar
Car: 1988 Camaro, 1986 S10, 2000 Harley
Engine: LS6
Axle/Gears: 3.75 9" ford trac loc
Mike
I have the C5 fronts, LS1 rears, I like them quite well . I've never autocrossed, but had a few panic stops. Much much better than the stock third gen stuff. I also have the 1LE prop valve. If I were racing, I would probably go with the adjustable valve. Dean
Eric-86sc
Apr 3, 2016 03:52 PM
sailtexas186548
Jan 19, 2016 12:21 PM
zayne0
Aug 24, 2015 07:22 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
