wheel bearrings shot fast >> Cause?
Old Nov 18, 2009 | 03:59 PM
bitchin_buick's Avatar
Car: 91' bird(WS6>>305TBI), 82'Regal
91Bird WS6 bought in the spring with terrible noise up front (passanger side) Not like metal to metal but a terrible noise > suspect wheel bearrings. While redoing the entire front brakes(Rotors,calipers,pads), replaced both inner and out wheel bearrings on both sides. Terrible noise is back, on the passanger side again... Rotor is smooth, not warped. Pads are fine. >>>Suspect wheel bearrings. What causes fast wheel bearring wear other than over tightening/under tightning?
Old Nov 18, 2009 | 05:05 PM
Re: wheel bearrings shot fast >> Cause?
Not certain if lack of good suspension suspension would play a part in this? I replaced the struts and end link bolts/bushings this summer as well as the above mentioned. Wheel bearrings keep going bad, ONLY on the passenger side.
Old Nov 18, 2009 | 05:52 PM
Guest
Guest
Posts: n/a
Any signs when you take it apart of it being overly loose or tight you will want to take note of.
Its possible there is damage to the spindle itself (could be bent), causing a bind or causing it to seem tight but work its way loose later. I had to replace my spindle because the bearing had worn from the center cup into the spindle where the face of the cup rides, not the center part. It wore a groove in the spindle on the area right next to where the seal is. With a new bearing it was fine, until the edge of that cup wore and it dropped back and the whole thing was loose and tore up both bearings. So inspection of parts is going to tell the story. Look for any discoloration on the spindle where the bearings ride as well.
Old Nov 18, 2009 | 05:57 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Inadequate lube.
JamesC
Old Nov 19, 2009 | 05:46 PM
This is great new info for me to investigate.... Thank you... Mike
Originally Posted by JamesC
Inadequate lube.
JamesC
Good point I forgot to mention & I bought the fancy more expensive stuff!. So not the case, here anyways... Filled all them holes long and hard.....
Old Nov 29, 2009 | 09:34 AM
DeanJ's Avatar
Car: 1988 Camaro, 1986 S10, 2000 Harley
Engine: LS6
Axle/Gears: 3.75 9" ford trac loc
Did you replace the races with the bearings? Bad races will cause this also. What mad max & james c said also. Dean
Old Nov 29, 2009 | 09:48 AM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
Deffinatly replace the races everytime you replace the bearings even if they look good. It doesnt take long at all. How tight do you tighten them?
Old Nov 29, 2009 | 02:27 PM
Replaced calipers/pads/bearrings(inner & outer). Rides great now! I think I may have not installed the wheel bearrings correct the first time(on that side) Thanks >>> She is great now!
dyeager535
Aug 28, 2015 08:10 AM
red90IROCls1
Aug 25, 2015 06:56 AM
Dialed_In
Aug 20, 2015 01:45 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
