Anyone ever use fluid injection to bleed your brakes?
Transmission: World Class T-5
Axle/Gears: BW 3.45
I think it's called a Phoenix Injector and you hook it up to the bleeder screw of any caliper. Then you inject brake fluid through it until all the air is pushed through your system and out the master cylinder.
Anyone ever use this?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Anyone ever use fluid injection to bleed your brakes?
never heard of that, wouldn't it push all the air into the master, requiring you to then take the master off and re-bench bleed it?
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Car: check
Engine: check
Transmission: check
I'm not keen on the idea of injecting the brake fluid into the system via a caliper/wheel-cylinder. Along with what //<86TA>\\ mentioned, what do you do when the M/C starts over flowing?
Have to be real careful with brake fluid, it is a great paint remover, and attracts moisture which promotes corrosion.
I like using a catch jar and a mity-vac to vacuum bleed the brakes. Quick, easy, and effective.
RBob.
RBob.
Axle/Gears: BW 3.45
RBob.
RBob.
I've used a mity-vac too, but some people say that you'll get a better "bleed" the old fashioned way - with a helper pressing the brake pedal. Any opinions on that?
Car: 86 Trans Am
I guess (don't know for sure), that it only takes a small amount of fluid to push those air bubbles out the master cylinder.
the vacuum bleeders work great, its all i've ever used
backtothe80s
Sep 5, 2015 12:39 AM
