Classic Industries 9bolt hard lines. Don't fit.
Old Jun 1, 2010 | 12:00 AM
87350IROC's Avatar
Car: 87' IROC
Has anybody purchased the classic industries 9 bolt hard lines? Mine don't seem to fit. Here are some pics of my old and new lines. The passenger side is pretty close but the driver side is way short. What do you think?
Part number: FRA8601S
So the part title says for BW axle, but the description says not BW axle. I still think this is supposed to be the 9bolt lines.
http://www.classicindustries.com/con...rchCatalogId=1
86-92 CAMARO/FIREBIRD REAR AXLE BRAKE LINES 4 WHEEL DISC WITH BORG-WARNER STAINLESS STEEL
Brake Line Kits: Except Borg Warner HD Axle. Reproduction brake lines for your early model Camaro are now available in OEM material for a stock look or stainless steel material which offers a longer life span and custom look! Each kit includes all thenecessary components. We keep a large inventory on hand for quick delivery! Note: Front to rear brake line kits are shipped double oversize. All lines have the correct coded fittings. All lines have been pre-fitted for easy installation. Each line ismachine double flared for a safe, no leak fit. All lines are clearly labeled for your convenience. Reproduced with the discriminating restorer in mind.
Old Jun 7, 2010 | 11:13 AM
VRROOMmaster's Avatar
Car: 1970 SS
Transmission: TH350
Axle/Gears: 12 Bolt Posi 373
Re: Classic Industries 9bolt hard lines. Don't fit.
Listings should read as follows:
FRA8401 - 1984-92 drum brakes exc. BW rear axle
FRA8601 - 1986-92 rear disc with BW HD rear axle
FRA8602 - 1986-92 rear disc exc. BW HD rear axle
Add an "S" to the end of the part number for Stainless Steel
However, none of the part numbers listed above look anything like the original line in your pictures. I would contact Classic Industries, ask for the tech department. Explain that none of the above items numbers match your original lines and ask them if you email them a picture, if they can send your picture to the manufacturer to get some answers.
Old Jun 7, 2010 | 11:35 AM
87350IROC's Avatar
Car: 87' IROC
I have been in contact with Classic. I figured out through a lot of research that 8601 is for a drum rear. 8602 is correct for 4 wheel disc 9 bolt. Should be the same part as for 10 bolts it would seem. I have received the 8602 and the fit looks good.
Azrael91966669
25
Jun 20, 2017 04:04 AM
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
Dialed_In
Aug 20, 2015 01:45 PM
