LS1 brake upgrade question
Old Jun 24, 2010 | 04:56 PM
lonesomeloser's Avatar
Car: 1983 Z28
I am trying to use the stock 3rd gen lines. Only one side of the metal block on the end will sit flush against the caliper. So, I flipped it over, tightened it down but the line wants to fold inward against the strut. Is there a better solution? Also, one side keeps oozing brake fluid underneath the block. Yes, I used the washers. I keep tightening it but it won't stop leaking. Any ideas?
Old Jun 25, 2010 | 07:00 AM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
Re: LS1 brake upgrade question
you might need a thicker washer on the inside mine did that
Old Jun 29, 2010 | 04:21 PM
Car: 1983 Z28
I got new longer lines, all new washers. Got everything assembled but it doesn't look like I can use the strut bracket. Does the routing of my brake line look ok? It's not secured to anything.
Old Jun 29, 2010 | 05:15 PM
bm87ta's Avatar
Car: 87 TA
Engine: 305 tpi
Transmission: auto
looks like it might start rubbing on stuff when your a arm starts moving and your steering wheel starts turning. For peace of mind secure it.
Old Jun 29, 2010 | 07:13 PM
Car: 1983 Z28
Could I even use the strut bracket? I would have the line folded in against the spindle. Any other ideas to secure it? Any pics would help, too.
Old Jun 29, 2010 | 09:00 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Though not LS1, you might get an idea from the following pic:
https://www.thirdgen.org/forums/vbga...image-8637.jpg
JamesC
Old Jun 29, 2010 | 09:51 PM
godreject's Avatar
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
Secure it i left mine like yours initially and the line ended up rubbing on my wheel. It began to wear on my new line and the line finally busted glad it happened in my driveway and not the street.
Old Jul 2, 2010 | 07:31 AM
Car: 1983 Z28
What sized screw is used to hold the bracket to the strut?
Old Jul 2, 2010 | 07:35 AM
tom86iroc's Avatar
Car: 1986 iroc
my SS lines didnt come with the piece on the line to secure with that c-clip so i wrapped a piece of rubber around the line with wire tires and tied it to the strut where the c-clip would originally go i'm getting the LS1 lines from eb miller since his new lines have the provision for the c-clip on the strut Name:  DSC00411.jpg
Old Jul 2, 2010 | 07:39 AM
JamesC's Avatar
Screw, (M8 x 1.25 x 20)
JamesC
Old Jul 2, 2010 | 07:45 AM
Car: 1983 Z28
JamesC
You rock.
Old Jul 2, 2010 | 05:17 PM
Car: 1983 Z28
Any tips on getting the clips over the hoses? Seems like the metal section won't stick up through the bracket hole enought to get the clamp on. Looks like it's at an angle but flush underneath.
Old Jul 6, 2010 | 12:16 AM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
When I sold my big brake kits to Spohn I used a rubber coverered Adel clamp I got from True Value for $1.50. Sold dozens of kits using this clamp.
Old May 29, 2011 | 03:45 PM
c2kvaticide's Avatar
Car: 91 camaro z28
Engine: built 305 w/milled vette 350 heads
Transmission: auto :(
Axle/Gears: 3:50s
what is has to be bought or made to mount the calipers and carries off the ls1 4th gen to the third gen ?
Frozer!!!
Jan 19, 2024 04:55 PM
sailtexas186548
Jan 19, 2016 12:21 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
redmaroz
Aug 16, 2015 11:40 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
