E-Brake Does Not Work
Old Jul 2, 2010 | 09:38 AM
jloomis95's Avatar
Car: 1992 CAMARO RS 25TH ANNIVERSARY
Engine: 3.1 V6
Transmission: AUTOMAGIC
Axle/Gears: STOCK
I have a 1989 Rs 5speed w/350
Recently finding out my E-brake does not work, as you can imagine i am not a happy man. I have done brakes before, but never anything with the E-brake.
Any advice, info, articles, and books suggested would be great. Thanks
Old Jul 2, 2010 | 09:48 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: E-Brake Does Not Work
Originally Posted by jloomis95
I have a 1989.... I have done brakes before, but never anything with the E-brake. Any advice...would be great.
You might start with the adjustment piece which in the tunnel over the drive shaft. Make sure the cables aren't frozen.
Disc or drum brakes?
JamesC
Old Jul 2, 2010 | 09:54 AM
jloomis95's Avatar
Engine: 3.1 V6
Axle/Gears: STOCK
drum brakes
Old Jul 2, 2010 | 10:04 AM
JamesC's Avatar
1. Pull parking brake hand lever exactly two ratchet clicks.
2. Raise and suitably support the car.
3. Tighten adjusting nut [on the equalizer] until the left rear wheel can just be turned rearward using two hands but is locked when forward rotation is attempted.
4. With mechanism totally disengaged, rear wheels should turn freely in either direction with no brake drag. It is very import that parking brake cables are not adjusted too tightly causing brake drag.
5. Remove support and lower car.
JamesC
Old Jul 2, 2010 | 10:18 AM
jloomis95's Avatar
Engine: 3.1 V6
Axle/Gears: STOCK
thanks alot
Old Aug 22, 2010 | 10:38 AM
neilb's Avatar
Car: 1986 sports coupe, 1984 F41
Engine: 3.8L Turbo SFI, stock 305
Transmission: 700 R4, 700 R4
Axle/Gears: 3.42:1, 3.08:1
The drum brakes must be properly adjusted before doing any adjustments with the cables. If your shoes are out of adjustment, the ebrakes will do nothing.
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
