LS1 upgrade front flex hoses
Old Aug 9, 2010 | 11:49 AM
skinny z's Avatar
Searching here (and other places like LukeSkaff.com or Flynbye.com) has yielded no spec on the front flex hoses needed when upgrading to the LS1 front brakes. I could order them outright from Ed Miller at Flynbye however if the parts don't fit for whatever reason, I don't wish to hassle him with a return.( He's difficult enough to reach when you want to make a purchase!) I would prefer to source locally.
The stock 3rd hoses are both too short and do not have the 90 degree hard line fitting at the banjo bolt. The stock 4th gen hoses are too short.
I'd like to keep the stock brake line bracket and location.
Somewhere I've read about a brake hose master catalouge although I can't find it on-line.
Who has done what to find these hoses?
Attached Thumbnails LS1 upgrade front flex hoses-3rd-gen.jpg   LS1 upgrade front flex hoses-4th-gen.jpg
Old Aug 9, 2010 | 05:07 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: LS1 upgrade front flex hoses
the 1le lines are what are usually used, however, im using earls lines for the single piston front brakes on my c5 setup with no probles at all. plenty of length
Old Aug 9, 2010 | 06:17 PM
skinny z's Avatar
The 1LE option for a 92 Camaro might do it then?
I'll check into that.
You bring up an interesting point with the Earl's lines though. Speculation is that Earl's (among others) have recently changed the supplier of their lines with less than satisfactory results. Buyer beware.
Old Aug 9, 2010 | 06:35 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
i was under the impression that earls no longer offers the lines at all?
Old Aug 9, 2010 | 09:03 PM
skinny z's Avatar
I sort of grouped Earl's in with a bunch of others. I did find this thread however.
https://www.thirdgen.org/forums/brak...ing-brake.html
I've never done any searching to confirm. Perhaps Earl quit rather than compete.
Old Aug 10, 2010 | 12:42 AM
fireburdluvr85's Avatar
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
if i may put in some input; the 1le lines with the ls1 fronts required me to move the line bracket on the strut up 2". the stock line fit perfectly. since i already bought them and had fluid in them there was no returning thats why i kept them. ill take pics eventually to post.
Old Aug 10, 2010 | 05:05 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I used the stock 1le hoses from rockauto (pn: BH38602/3, R/L, raybestos, $12/ea). They are 21¼" length, as opposed to the stock 19". The stock will work but, they got a little to tight at full lock for my taste.
(ignore that I don't know where I put my line bracket...)
Old Aug 10, 2010 | 07:25 AM
skinny z's Avatar
Any and all input is appreciated. I'd like to see pics too.
Do the 1LE hose have the 90 degree fitting at the banjo bolt as in the picture of the 4th gen line in the post above?
Old Aug 10, 2010 | 01:33 PM
deadbird's Avatar
Engine: TPI 305/ v6
They don't but, it's not really an issue (at least, not to me).
Old Aug 10, 2010 | 02:23 PM
skinny z's Avatar
Looks resonable enough.
I've just ordered the full set for a 92 Camaro with the performance brake package.
Old Aug 10, 2010 | 05:41 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
I had a similar problem when I needed new lines for my BAER setup. $45 each plus shipping
16" -3AN brake lines ($30)
10mm, -3AN banjo's with hardware ($12x2)
-3AN to 10MM x 1.0 inverted flare fitting ($10x2)
I saved a little, but it's nice to know I sourced all the parts myself.
Old Aug 11, 2010 | 05:26 PM
skinny z's Avatar
I anticipate the 1LE lines will just bolt-in. Won't know for a week until I'm back home to try them out.
Old Apr 7, 2012 | 12:40 PM
z 28 jari's Avatar
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
How was it,were those 1LE front brake hoses bolt on(and long enough)to ls1 front brakes?
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
