Drum To Disc bbrake
Car: 91 Pontiac Firebird
Engine: SMall Block 350 TBI
Transmission: 5-Speed
Axle/Gears: Stock(for now)
Drum To Disc bbrake
I jus bought a new rear end for my 91 firebird. Will there b any issue with the proportioning valve and the amount of pressure sent to the rear disc being that it requires less? or will it sorta set itself so to speak
Car: 87 iroc z28
Engine: 89 C4 TPI ,
Transmission: ZF6 speed , 89 C4
Axle/Gears: 89 corvette rear end
Re: Drum To Disc bbrake
We stuffed a Disc rear end in my friends 86 car ,with no problems.But I would test it out,check the valve size on the donar car and compare !!!!
i did i pulled it off and all jus in case but one of the fasteners were stripped out...hents the leak on the left side of engine bay
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Car: 91 camaro rs
Engine: 305 (350 vortec in dec.)
Transmission: Wc-T5
Axle/Gears: 3.08 (3.42 in dec.)
I know this has been asked a million times I'm sure, but I'm trying it myself and need help. I have a 86 donor car iroc, with a 90 z28 rear end with disc breaks, I want to put those disc breaks on my 92 25th anniv. What would I need to do to make the most simple swap? Whole rear end, just change brakes, or what?
JamesC
my rear end is a nine bolt....does everything still wrk the same?
KO1
16
Oct 15, 2015 05:00 PM
