9bolt with C5 calipers
Old Aug 25, 2010 | 02:21 PM
spade's Avatar
Car: 1989 Mystery Firebird
Engine: 350 FIRST TPI
anyone do this? how hard is it? pics? writeup? kept the ebrake? anything would help...
Old Aug 25, 2010 | 10:42 PM
spade's Avatar
Re: 9bolt with C5 calipers
Anyone?
Old Aug 30, 2010 | 03:38 PM
spade's Avatar
im assuming no?
Old Sep 6, 2010 | 07:46 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Yes, the brackets are done just not tested yet.
Ed
Old Sep 6, 2010 | 08:19 PM
abcx09t's Avatar
Car: 1987 IROC-Z; 2012 Ford Raptor
Engine: Modified 350
Hey, if you are working with Ed Miller, you don't need any other help. I worked through the front and rear brake upgrade with Ed a couple years, maybe more, ago. Brakes have not been a problem and the install was easy. The only difficulty I had was the rear driver side with the brake line. The welded on lower control arm relocation bracket makes it a tight fit when you bleed the brakes, but it works. Ed is a good guy.
Old Sep 7, 2010 | 11:25 AM
spade's Avatar
Dude this I definitely know Cause I have his c5/ls1 hybrid system for the front brakes..... Plus I had started this thread before I had sent him the emai asking about this.......
gearheadotaku
Jul 26, 2015 04:33 PM
SLEEPER 86
May 24, 2014 08:30 AM
geoffz28
Brakes
16
Oct 21, 2011 02:20 PM
chevypower
Brakes
41
Feb 28, 2004 06:40 AM
ANDYZ28
Nov 14, 2000 05:14 PM
