strange brake problem
Car: 86' Sport Coupe
Engine: LG4 305
hey guys, I searched the entire brake section and I did not find anything about my situation so I figured I would make my own.
This is going to be kind of hard to explain but here it goes.
When my car has been sitting for awhile the brakes act up for a couple of minutes then they go back to normal. What happens is, if I press down on the brake pedal, the front tires like lock up and they just skid. So I have to like barely press down on the brakes for the first couple of minutes I am driving.
Recently I had the front rotors resurfaced, got new brake pads, and caliper bolts. After the first couple of minutes when the brakes are acting funny, they work perfectly. I mean the car has never slowed down so smoothly. It usually only has the problem in the morning since it has been sitting overnight, and when I get off of work, since it has been sitting for 8 hours.
any feedback would be appreciated, thanks
Tash
Tash
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: strange brake problem
if the rotors rust a little, the brakes will be grabby for the first could applications.
how are the calipers? the boots may be shot and the pistons are rusting and seizing up a little.
remanned calipers are dirt cheap at most parts stores
Engine: LG4 305
I think the calipers are in pretty good shape, I'll go out and take a look at em.
Car: 86 Trans Am
new, resurfaced or not, they are bare steel and rust quickly when its damp or it rains. happens to every car in the world. not so depending on how the wheels are designed.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
You might consider replacing the front lines, which sometimes collapse internally and act as a check valve.
JamesC
JamesC
Car: 1991 z28
Engine: 5.7 tpi
Transmission: th700r4
same thing just happened to me. I replaced the front brake lines and that solved the problem. Cost was around $30 including brake fluid (diy). Hope that helps. Randy
Car: 1989 GTA
Engine: pending install 383 tpi
Was doing it on my front ds after the car sat for 7 years in a barn, replaced the line and rebuilt the calipers no problem since
red90IROCls1
Aug 25, 2015 06:56 AM
