Does brake fluid go bad?
Old Sep 12, 2010 | 09:04 PM
chewiemusic's Avatar
Car: 1985 IROC-Z
Engine: 305 (5.0) TPI
As the title ask, can brake fluid gum up or go bad from sitting while in what was a fully functioning brake system?
Basics behind question... car sat, calipers rusted/seized, replaced calipers, and no fluid or pressure is getting to the new caliper to compress it. There don't appear to be any flaws in the lines, and they were fully functioning before storage.
Thanks.
Old Sep 12, 2010 | 09:17 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
Re: Does brake fluid go bad?
It could get moisture in it and cause problems internally in the system.
Old Sep 12, 2010 | 09:22 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Moisture can cause the fluid to go bad. However, it wont cause your problem. There is something else wrong. I would recommend though to bleed out all of your old fluid and replace it all.
Old Sep 12, 2010 | 10:25 PM
nascarfan7's Avatar
Car: 1991 Z28
Engine: 5.7
Here's an excellent article on brake fluid.
http://www.stoptech.com/tech_info/wp...fluid_1a.shtml
How long did it sit?
Old Sep 12, 2010 | 10:45 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Brake fluid is hygroscopic meaning it absorbs water. Brake fluid is really a mineral oil. If you read your owner's manual or any owner's manual, you'll see that all the fluids in a vehicle need to be changed at specific intervals, including brake fluid, tranny oil, diff oil and antifreeze which many people never change.
Brake fluid is a clear liquid. If it's dark or black then it's becoming contaminated with water and should be flushed. Water in brake fluid cause rust which doesn't work inside the hydraulic system.
Old Sep 13, 2010 | 09:47 AM
Car: 1985 IROC-Z
I would like to be able to bleed out the fluid, but right now the two bleeders I opened aren't pushing any fluid through them.
I am leaving shortly to purchase and replace the remaining calipers and will be purchasing some brake lines in case that needs to be done. I am just confused because their appears to be no damage to the lines, and the fluid in the reservoir looks good yet it will not push the piston in the caliper or move fluid out of the bleeder.
Old Sep 13, 2010 | 09:52 AM
Car: 1985 IROC-Z
As far as sitting, the car hasn't done much since 2004.
It was started and ran at least once a year though the timing was off and ran rough. Oil and gas were maintained for the most part, stabil was used and now has fresh oil in addition to plugs and wires, distributor is still in great shape and was new before sitting, the fuel filter has now been changed, coolant was a fresh flush before sitting and still looks great in the new radiator, and the tranny was supposedly flushed and new filter too (i wasn't there for that part.) I didn't do anything with the brake fluid because i hadn't heard of a need to if the system didn't leak.
Old Sep 13, 2010 | 10:05 AM
built91Z28's Avatar
Does the brake pedal move?
Old Sep 13, 2010 | 11:50 AM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
The rubber brake lines are known to break down internally and restrict the flow of brake fluid, replace them and let us know is the problem persists.
Old Sep 13, 2010 | 11:54 AM
built91Z28's Avatar
Not a bad idea. Even if the rubber lines are not the problem, getting rid of 25 year old brake lines before they collapse is a good idea.
Old Sep 13, 2010 | 12:24 PM
Yes, I have made them a routine part that I replace if for any reason I replace more than just the pads. Its nice to have that reassurance. They're about $12 a side, FYI.
Old Sep 13, 2010 | 02:54 PM
tylercamaro's Avatar
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
yeah definitely the line, my car sat for 4 years and i tired bleeding the brakes and nothing came out, apparently the 25 year old line didnt allow fluid to flow so its a safe bet that your problem is more than likely the line itself
Old Sep 14, 2010 | 02:39 AM
Car: 1985 IROC-Z
I replaced the rubber lines, since they were the problem and I was able to drive the car. First real road experience since '04. Today was a good day.
I learned I am nowhere near daily driver from the little jaunt.
Thank you much for the assistance in getting my baby back on the road.
Old Sep 14, 2010 | 09:38 AM
Awesome!
Glad we could help you figure it out!
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
backtothe80s
Sep 5, 2015 12:39 AM
kyleb24
Aug 15, 2015 08:24 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Leggman1
Aug 6, 2015 04:15 AM
