proportioning valve
Old Sep 22, 2010 | 11:19 PM
quick87formula's Avatar
Car: 87 formula
Transmission: 700
Axle/Gears: 12 bolt strange 3.73
proportioning valve
can any one tell me what are the symptoms of a bad proportioning valve.
i am having a problem were my front brakes are not holding. the car wont hold after hitting 1500 rpm. also when in Park i pump up the brakes then give it gas the peddle will lose power. i changed the master and i changed the booster. everything in the car is basically new. the car has been setting. i also have the SS braided lines for my brakes but they all bleed good. please any help.
Old Oct 2, 2010 | 06:47 PM
n1ffer's Avatar
Car: 1983 Crossfire Recaro T/A
Engine: 5.0L Crossfire
Transmission: Upgraded 700R4
Axle/Gears: 3:23
Re: proportioning valve
A prop valve shouldn't cause what you are describing. It is basically a metering valve to direct fluid proportionately to the front and rear brakes at a certain ratio.
Based on your upgrades and tests, one thought - have you checked the booster check valve, grommet, vacuum hose, vacuum hose connections for a vacuum leak?
Maybe something didn't go back together correctly on your booster?
SPEEDY Z28
Brakes
16
Apr 18, 2016 02:46 PM
sleprock
Sep 24, 2015 04:33 PM
HikoriYami
Sep 21, 2015 07:11 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
