Cheap Proportioning Valve Upgrade
Old Oct 30, 2013 | 01:38 PM
  #251
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Re: Cheap Proportioning Valve Upgrade
I have a couple, PM me if you need one.
Old Nov 9, 2013 | 07:56 AM
  #252
TrackAficionado's Avatar
Any one still have a 30lb spring? pm or email me plz 01knightridergt@gmail.com
Old Nov 9, 2013 | 05:50 PM
  #253
55ChevyMan's Avatar
Car: 55 chevy Belair & 86IROC Z
Engine: 350 in 55 86IROC Z LT1
Transmission: 55 4speed IROC Z4L60e
Axle/Gears: 12 bolt 410 in55 and 342 inCamaro
I have one left
Old Nov 13, 2013 | 03:07 AM
  #254
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
I did the same thing a while back.
Old Nov 19, 2013 | 10:56 PM
  #255
Slush92RS's Avatar
Car: 92RS
Engine: LS 402 inwork
Transmission: TH350
Axle/Gears: 10 bolt,3:73's
I'm making the swap to manual brakes, will this spring mod still make an improvement?
If anyone has a spare spring PM me and I will Paypal you the funds
Old Nov 22, 2013 | 03:19 PM
  #256
55ChevyMan's Avatar
This for 4 wheel disc and improves rear disc brakes
Old Dec 2, 2013 | 11:34 AM
  #257
Brian Wishin's Avatar
Car: 88 Formula
Engine: 355
Transmission: worked 700r4 2500 stall
Axle/Gears: Strange Engineering 12 bolt 3:73
Originally Posted by jersyboyy
just ordered a pack of 5 if any one needs one pm me
Hey there, By any chance do you have the part number for this spring or do you have any extras your willing to sell?
Old Dec 2, 2013 | 05:43 PM
  #258
55ChevyMan's Avatar
part # 1ncf2 spring from Granger
Old Dec 7, 2013 | 10:30 AM
  #259
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Did this the other day, mine was horrible, gummed up, spring stuck.
Front spring as bad, I'm sure, anyone know what spring would work for the front setup?
Old Dec 10, 2013 | 12:44 PM
  #260
Gregs_GSXR's Avatar
Car: '91 Camaro
Engine: LSx
Transmission: 4l60e
Axle/Gears: posi
i just ordered some from Grainger today, pick them up tomorrow, cleaned up my prop valve, dirty and gummed up inside. I will have some left over
Old Dec 10, 2013 | 01:19 PM
  #261
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
I'm not sure what you mean by manual brakes.
Old Dec 10, 2013 | 01:24 PM
  #262
Car: 1971 Camaro
Engine: 427
^ manual brakes means no power assist. No booster
Old Dec 12, 2013 | 07:43 AM
  #263
Dominic Sorresso's Avatar
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
Any idea of a proportioning spring for use with C6Z06 brakes?
Old Dec 12, 2013 | 03:15 PM
  #264
Gregs_GSXR's Avatar
Car: '91 Camaro
Engine: LSx
Transmission: 4l60e
Axle/Gears: posi
it should work with any 4 wheel disc, Im currently running CTS-V on all 4 corners on mine, which I had it set up with LS1 before
Old Dec 14, 2013 | 05:19 PM
  #265
tglennon11's Avatar
Car: 87 IROC
Axle/Gears: LS1 10bolt w/ 3.73
hey guys, I have been through this thread and either i didnt see it or its not there, but has anyone run LS1 brakes front and rear with the spring change in a stock 87 drum prop valve? If so what spring?
Gregs_GSXR might be the best one to answer if you can.
Old Dec 14, 2013 | 05:31 PM
  #266
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
I had C5 brakes on my 84 Vette. Doug Rippie sells a proportioning spring for that upgrade which I used. Worked fine. I think it was about $12.
Old Dec 15, 2013 | 09:51 AM
  #267
tglennon11's Avatar
Car: 87 IROC
Thanks Dominic!
Old Dec 15, 2013 | 11:30 AM
  #268
Gregs_GSXR's Avatar
Car: '91 Camaro
Engine: LSx
Transmission: 4l60e
Axle/Gears: posi
part # 1ncf2
i have some of these left over and is what Im running on my current set up
Old Dec 27, 2013 | 08:44 AM
  #269
cam406406's Avatar
Car: 1989 TA
Engine: 406
Transmission: 400
Axle/Gears: 9 inch
Can u remove spring for full pressure?
Old Dec 27, 2013 | 09:50 AM
  #270
82tarecaro's Avatar
That would be very dangerous unless you are installing an adjustable proportioning valve. Full pressure to the rear brakes would cause them to lock up before the fronts, possibly causing you to lose control of the car.
Old Dec 27, 2013 | 11:46 AM
  #271
cam406406's Avatar
Car: 1989 TA
Engine: 406
Transmission: 400
Axle/Gears: 9 inch
I understand that but with wilwood and 13" roters on front and the crap irons on the rear my fronts Do all the work Just looking for more out of the rear
Old Dec 27, 2013 | 12:29 PM
  #272
82tarecaro's Avatar
If you lock up the rears first, the rear will kick out and you will lose control of the car. Very dangerous - it's your car but it is very irresponsible to do something like that and put everyone else in danger who happens to be on the road when you lose control.
Put in an adjustable proportioning valve and consider beefing up the rear brakes to a better set up so you get the bias set properly.
Old Dec 27, 2013 | 01:10 PM
  #273
55ChevyMan's Avatar
No No
Old Dec 27, 2013 | 01:14 PM
  #274
Car: 1971 Camaro
Engine: 427
Have you tried the spring upgrade?
Old Dec 27, 2013 | 04:27 PM
  #275
cam406406's Avatar
Car: 1989 TA
Engine: 406
Transmission: 400
Axle/Gears: 9 inch
No not yet
What spring do u recommend
Old Dec 28, 2013 | 10:42 AM
  #276
Gregs_GSXR's Avatar
Car: '91 Camaro
Engine: LSx
Transmission: 4l60e
Axle/Gears: posi
No not yet
see post 268
Old Dec 28, 2013 | 10:53 AM
  #277
Car: 1971 Camaro
Engine: 427
I have a few springs left as well. $5 shipped. PM me if interested.
Old Feb 10, 2014 | 03:30 AM
  #278
87_LG4's Avatar
Car: '87 Camaro SC
Engine: 305 LG4
Transmission: TH-700R4
Just saw this thread. Why have I not seen this thread before?!?
Anyways. Looking for a spring to put in my 87. I've got LS1/C5 front and stock drums rear with the original prop valve. Rears will keep turning when the car is jacked up and brake pedal floored, so I definitely need to do something about that.
In my original post I asked if anyone could send a spring to Norway where I live, mainly because I didn't know of any places in Norway that makes springs like these. But now I might have found someone who does. But I wanted to check if the measurements I've used are correct.
So I am looking at four different springs:
- They all have an outside diameter of 12.19mm, which should convert to .480"
- They all have an uncompressed length of 38.10mm, which should be 1.5"
Spring #1 has a thickness of .055", an inside diameter of .37", 13.5lb and a spring rate of 18.33lb/inch
Spring #2 has a thickness of .059", an inside diameter of .36", 15.5lb and a spring rate of 24.67lb/inch
Spring #3 has a thickness of .063", an inside diameter of .35", 19.1lb and a spring rate of 31.63lb/inch
Spring #4 has a thickness of .067", an inside diameter of .34", 22.3lb and a spring rate of 40.31lb/inch
Will any of these fit my car and application?
Also, are you guys changing the prop valve, or the metering valve?
Thank you.
-Dennis
Last edited by 87_LG4; Feb 10, 2014 at 11:22 AM. Reason: Just wanted to try out my new signature image :)
Old Feb 18, 2014 | 03:39 AM
  #279
87_LG4's Avatar
Car: '87 Camaro SC
Engine: 305 LG4
Tried the 15.5 lbs spring this weekend. It really made an improvement on my LS1/drum setup. Only had time to do a short drive without any hard braking, but the pedal feels better and the brakes grip firmer and faster than before. Now I actually believe my brakes can stop my car. Probably one of the quickest and cheapes upgrades anyone can do to these cars. Love it
Old Mar 8, 2014 | 05:28 PM
  #280
83L69Camaro's Avatar
Car: 83 L69 Z28 T tops
Engine: 305 H.O.
Transmission: 5 spd
Axle/Gears: 3:73
Been reading all the threads on the brakes. I have a 83 Z28 with 4 wheel disc, ordered it new, and the rear brakes have never worked. Rotors and pads are like new, 66K mi. So far I've replaced the MC, PPV, and no luck. Bought a new PPV from Summit and the brakes worked fine after they were bled. Then while holding the pedal it went down and they haven't worked again. checked the lines to see if they were plugged and they're clear. I'm at a loss, been doing this for close to 50 yrs. and never had this much trouble with brakes. Just went to bone yard and got a PPV off an 87, looks like the one in the threads got springs to change the spring just hate to change the fittings to metric and not have it work. When you push on the pedal good fluid comes out of the MC for the front breaks but the rear just seems to run out very slow unless you jam on the brake pedal then it will shoot out. Trying to keep it stock. Allot of great information in these threads hope someone can help an old Camaro guy out.
Old Mar 8, 2014 | 05:40 PM
  #281
mjdavis68's Avatar
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
Just placed an order and will have xtra
Old Mar 11, 2014 | 04:22 PM
  #282
mjdavis68's Avatar
got them today
Old Mar 13, 2014 | 05:59 PM
  #283
Angelduran5858's Avatar
Car: 87 Camaro Z28
Axle/Gears: 4th Gen 3.42
Wondering how much to sell one?
Also which ones did you get?
Old Mar 13, 2014 | 06:11 PM
  #284
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
My upgrade was to get a Disc/Drum brass hotrod prop valve off ebay and convert everything to standard lines.
[ditching the metric line stuff]
Old Mar 18, 2014 | 11:45 PM
  #285
resop27's Avatar
Car: 89 325is, 91 z28
Engine: 2.5l 6, l98
Transmission: t56
Axle/Gears: 3:42
if anyone has one of these springs for sale pm me
Old Mar 30, 2014 | 08:08 AM
  #286
camaro211z28's Avatar
Car: 92 camaro RS
Engine: vortec 350/396
If I keep stock 3rd gen rearemnd and pull drums off and put factory 3rd gen disc brakes on the rear. Will I have to upgrade the spring or get a proportioning valve off a factory disc brake car?
Old Mar 30, 2014 | 09:37 AM
  #287
GTAman's Avatar
Car: 1988 Trans am GTA
Engine: corvette 350 swap
Transmission: t-5 swap
Axle/Gears: 3.27:1 borg warner 9-bolt w/ PBRs
Good luck finding a disk brake prop valve. The spring upgrade is definitely worthwhile.
Also I have 4 springs left.
Old Mar 30, 2014 | 09:51 AM
  #288
Car: 92 camaro RS
Im at junkyard right now getting two of them. Lol. I got the disc brake setuo off this same car last weekend but didnt think about the prop valve. But there is two rear disc brake camaros here at the yard one is already stripped though. Nobody sells the prop valve new for disc brakes?
Old Mar 30, 2014 | 09:52 AM
  #289
Car: 92 camaro RS
Im at junkyard right now getting one now. Lol. I got the disc brake setuo off this same car last weekend but didnt think about the prop valve. But there is two rear disc brake camaros here at the yard one is already stripped though. Nobody sells the prop valve new for disc brakes?
Old Mar 30, 2014 | 12:40 PM
  #290
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
no one sells them direct fit, but you can find plenty of uni hotrod brass prop valves, in disc disc or disc drum....... nothing about a prop valve makes it a one car design.
Id avoid junk yard million mile parts and longevity......
Old Apr 3, 2014 | 11:44 AM
  #291
87camaro kid's Avatar
Car: 1987 Z28
Are you willing to pop one in the mail to south jersey? Let me know the cost.
Old Apr 3, 2014 | 04:06 PM
  #292
Car: 1971 Camaro
Engine: 427
Got several springs left as well, $5 shipped
Old Apr 4, 2014 | 01:28 PM
  #293
mjdavis68's Avatar
I'm out, all sold
Old Apr 5, 2014 | 03:43 PM
  #294
Magman's Avatar
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
I just ordered a pack of 5; 1NCR5. Expected delivery of Tuesday, Pm me if you need one.
Old Apr 5, 2014 | 05:09 PM
  #295
Engine: 305 H.O.
Transmission: 5 spd
Axle/Gears: 3:73
Got the brakes done. Got a Proportioning valve bleed tool and help out with the bleeding.
Works real good if you don't have one in your toolbox your missing out takes the proportion valve issues out of bleeding brakes. Used a new proportioning valve from Summit, rear brakes work great. Thanks to third Gen.org for all the help.
Old Apr 5, 2014 | 05:12 PM
  #296
1991sleeper's Avatar
Car: 1991 firebird
Engine: TBI 305 (built)
Axle/Gears: 4.10
I need one !... I have factory disc brakes out of a 92' GTA still running the factory 91' drum valve
91' bird 305 TBI T-5, trick flow heads, 4.10 gears, full UMI setup, track times coming soon!
Old Apr 5, 2014 | 06:16 PM
  #297
scoflaw's Avatar
Car: 1988 gta
Engine: 383
Axle/Gears: 9 bolt 3:23
Using the 1ncr5 spring. Can anybody recommend another spring for more rear brake pressure?
Old Apr 12, 2014 | 07:59 PM
  #298
Magman's Avatar
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
I have 3 springs available. 1NCR5 PM me if you want one.
Old Apr 14, 2014 | 11:39 AM
  #299
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
Hey guys,
I was thinking.
My car and at least one other F-body and one other car are having the issue of the drums locking up fairly quickly even with moderate pedal pressure.
What would happen if the spring in the prop valve were to weaken over the years and lose some force?
I guess it would compress real easy and give way to the pressure coming down the line, just like when someone slams the brakes.
Is this correct?
Old Apr 15, 2014 | 09:24 PM
  #300
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
I need an R5 and will pay shipping. If someone has one please PM me!!!
