Cheap Proportioning Valve Upgrade
Old Apr 20, 2014 | 12:03 PM
  #301
1991sleeper's Avatar
Car: 1991 firebird
Engine: TBI 305 (built)
Axle/Gears: 4.10
Originally Posted by Magman
I just ordered a pack of 5; 1NCR5. Expected delivery of Tuesday, Pm me if you need one.
Payment sent / item received thanks !
91' bird 305 TBI T-5, trick flow heads, 4.10 gears, full UMI setup, track times coming soon!
Old Apr 27, 2014 | 11:59 PM
  #302
TennesseeIroc-Z's Avatar
Car: 1988 Iroc T-top
Engine: 350 w/typical bolt-ons
Transmission: 5 speed
Axle/Gears: 3.42 zexel, TEN chromoly 28 splines
Re: Cheap Proportioning Valve Upgrade
Anyone have any extra springs left? Need one for a drum to LT1 disc swap....
Old Apr 28, 2014 | 12:05 AM
  #303
bttrflybird's Avatar
Car: 89' Bandit 2 #104 of 500
Engine: LS1 5.7L
Transmission: 4L60e
Axle/Gears: 3.23 posi
I am going to Grainger in the AM and getting a pack of 5 i think. i will have 3 leftover 22lb spring pm me if you would like one.
Old Apr 28, 2014 | 06:29 PM
  #304
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Got two of 1NCR5 springs to sell, $6 shipped.PM if interested.
Old Jul 8, 2014 | 12:09 AM
  #305
willexoIX's Avatar
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
Has anyone tried a 19 and 22# spring on factory 89 disc/drum? Curious which would be a better choice for stock.
Old Jul 31, 2014 | 07:59 AM
  #306
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
I did the 19 on a factory 89 with disk/drum, worked perfect. 22 might have been too much.
I have the 19 now in the same 3rd gen prop valve with an Astro master and Hydroboost, 4th gen front disks and big ford drums. Hitting the brakes is like slamming into a wall.
Old Jul 31, 2014 | 02:01 PM
  #307
willexoIX's Avatar
Thanks just what I needed to hear
Old Aug 15, 2014 | 11:42 PM
  #308
TheIgnitious's Avatar
Car: 82' Z28 Crossfire
Transmission: Turbo 350
I've got an 82 rear drum proportioning valve and wanted to see if this mod would work not only on an 82 but also going from drum to disk. If so what spring should I use and where would it go on the 82 valve?
Old Oct 2, 2014 | 01:04 PM
  #309
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
Anyone have a 1NCF2 19lb spring they want to sell? From what I've read on this thread I think that is what would be best to start with on my car. Its a 91 with disk/drum brakes and I want to install this spring when I convert to rear disk.
Old Oct 2, 2014 | 01:06 PM
  #310
I do, PM me
Old Jan 2, 2015 | 10:06 PM
  #311
IROCgiraffe's Avatar
Car: '87 IROC-Z | '99 SS
Engine: LB9 | LS1
Transmission: 700R4 | T56
just requested a 22lb from Grainger, will pick it up this week
Old Feb 6, 2015 | 12:23 PM
  #312
Trans Am GTA's Avatar
Car: Pontiac Firebird Trans Am GTA
Engine: 5.7L L98
Transmission: Automatic 700R4
Axle/Gears: 2.77 standard
Hello Jersy Bouyy
Do you still have the spring (1ncr5)
Old Feb 6, 2015 | 01:44 PM
  #313
Engine: 5.7L L98
Hey Napster
I need a set. Do you still have them?
Old Feb 6, 2015 | 02:46 PM
  #314
jazzdadss's Avatar
Car: 1989 IROC LSX
Engine: Swapped LS6 Forged by LME
Transmission: 4L65E
I just ordered a pack for mine (1NCR5). We'll see if it helps.
Old Feb 12, 2015 | 11:38 AM
  #315
Prime's Avatar
Car: 91 Firebird Vert
Engine: LO3
I just ordered a pack of the 1NCR5 springs, will give them a try this spring. Hope it improves the rear brakes and pedal feel.
Old Mar 5, 2015 | 10:59 AM
  #316
Doobie52's Avatar
Car: 1992 Trans Am
Engine: 6.0 LQ4
Transmission: T56 Magnum F
Does anyone have a 1NCF2 spring they'd like to sell? If so, send me a PM with your PayPal info. Thanks
Old Mar 10, 2015 | 05:36 PM
  #317
Debased's Avatar
Car: 92 rs sorta white
Engine: L33 5.3
Transmission: Ctsv t56 converted to fbody
You don't have to set up an account with grainger anymore you can just got to their site and order them.
Old Mar 16, 2015 | 01:50 PM
  #318
fast400's Avatar
Car: 89 TTA
Engine: 3.8
Transmission: 200r4
I'm confused. The 1NCR5 shows up as a 30 lb/in spring. The 1 NCR8 shows up as 20lb. Which one is right for a stocke 1LE setup?
Old Mar 19, 2015 | 02:20 PM
  #319
fast400's Avatar
Car: 89 TTA
Engine: 3.8
Transmission: 200r4
Anyone have a couple 1NCR5 springs they want to sell me? I'm at a Military APO. USPS is the only way I can get them, and Grainger won't ship to APO.
Old Mar 25, 2015 | 11:58 AM
  #320
jbenge's Avatar
My 91 Camaro had disk/drum brakes from the factory. I installed a Strange 12 bolt rear with Wilwood disk brakes over the weekend. I change the proportioning valve spring to a 1NCR5 and the brakes work well. FYI for anyone doing a similar swap
Old Mar 26, 2015 | 04:16 PM
  #321
kaotik's Avatar
Car: 1991 Camaro Z28 Clone
Engine: 350 w/TBI
Transmission: WC T-5
Axle/Gears: Spicer 3:73 Auburn Posi
I have (4) 1NCR5 springs left if anyone needs one. $5 shipped. PM your address.
To help contribute to the thread, and for those with a similar setup as mine, I have a 1991 Camaro RS. Came with Factory Disc front and Drum rear. I swapped out the rear end for a factory 3rd gen 10 bolt disc brake rear end. (Still had drum brake prop valve). The rear end was upgraded with Splicer axels, 3:72 gears, Auburn POSI, and cross drilled / slotted rotors. (I know only the rotors matter for this discussion, but...) I added the 1NCR5 to my prop valve and noticed a difference in braking power!
I also have a Wilwood Front brake kit on my car, so this was a pleasant surprise.
Remember... You MUST bleed the back brakes for sure, and its encouraged to do the front too... If you skip this, any gain you think you feel is in your head. They wont function to their potential without this being done.
Old Mar 30, 2015 | 03:32 PM
  #322
kaotik's Avatar
Engine: 350 w/TBI
3 left...
Old May 25, 2015 | 07:07 AM
  #323
J.C. Denton's Avatar
Car: 85 Iron Duke, 88 GTA and 92 TA
Ok i have read the whole thread by now and have a question:
I have a 92 Firebird with factory Front Disc and Rear Drum brakes. And I don't wanna convert to rear discs since I have rebuilt all rear brake parts a few weeks ago.
Will the 1NCR5 spring improve my brake or will it not work with rear drums?
If it will work, is anyone here who can send this little spring to Germany in an envelope or small package? I can pay with PayPal.
Greetings!
Old May 26, 2015 | 07:27 AM
  #324
55ChevyMan's Avatar
Car: 55 chevy Belair & 86IROC Z
Engine: 350 in 55 86IROC Z LT1
Transmission: 55 4speed IROC Z4L60e
Axle/Gears: 12 bolt 410 in55 and 342 inCamaro
not sure I used it but I have disc brakes on all four and it help my 86 IROC Z but I have disc in the back
Old Aug 2, 2015 | 02:24 AM
  #325
Genopsyde's Avatar
Car: 91 RS
Engine: 355
I have a pack of both p/n's. If anyone needs one, just pm.
Old Dec 10, 2015 | 08:26 PM
  #326
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
where can I get a new prop valve
Old Jan 26, 2016 | 04:10 AM
  #327
RaceFace's Avatar
Car: 1987 F-bird
Engine: 350 Vortec
Transmission: Manual
Anybody tried this instead of spring inside of prop valve?
http://www.autopartswarehouse.com/sk...P11210001.html
Old Jan 26, 2016 | 06:59 AM
  #328
kaotik's Avatar
Engine: 350 w/TBI
I've never seen that yet, but id like to hear from someone that has. Concerned it might be just enough to lock the back brakes. I run a Upgraded spring (I believe I have the 22#) and it works great.
Old Jan 29, 2016 | 10:45 AM
  #329
Amillionoh7's Avatar
Car: 92 RS
Engine: Sbc With h/c/i/e holly4150
Transmission: 700r
I have 4 left over 1ncr5 springs if anyone wants
Old Jan 29, 2016 | 01:26 PM
  #330
BOTTLEDZ28's Avatar
Transmission: A4
Total price shipped to 02790?/ (Mass)
Old Jan 29, 2016 | 02:52 PM
  #331
Car: 92 RS
Transmission: 700r
pm ur address I just sent out 2 was only a couple bucks. I will just send the last 2 to you
Old Feb 20, 2016 | 02:38 PM
  #332
foxxtrot82's Avatar
Car: 91 camaro z28
Engine: 350 tpi speed density
Axle/Gears: 323
the 1ncr5 (19 lb) spring didn't do much for me. would not stop wheels when lifted off ground. bled the brakes multiple times. no improvements. put in an 1ncf2 (22 lb) spring today, didn't want to fit to well on the internal parts of prop valve. very hard to screw cap on. I can now stop the rear wheels without shifting into neutral. I haven't bled the brakes yet either and I can still tell a noticeable difference just in the driveway on gravel. I don't think you have to bleed the brakes after the spring swap as long as the prop valve is left on the car. fluid leaks out very slowly not letting air in. didn't lose much fluid removing the spring either. I'm not much of a mechanic, but the experts would still say bleed the brakes. so far I'm happy with the results.
Old Apr 7, 2016 | 12:10 PM
  #333
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
foxxtrot82 what kind of system do you have? LS1 fronts? PBR rears? rear drums?
I just ordered some 1NCR5's from Grainger they have a warehouse about 5 minutes from my work. I'll be putting in the LS1 fronts this summer and I have already converted to disk in the rear. I'm hoping this spring will keep me from sourcing an 1LE prop valve. If the 1NCR5 doesn't work i'll try the 1NCR2.
Old Apr 7, 2016 | 01:17 PM
  #334
Ty92Z's Avatar
Car: 1992 Z28 1991 RS
Engine: LB9 LO3
Transmission: 5 speeds
I did the 1NCF2 and it works very well. I upgraded to LS1s both front and rear. Have 3 left if anyone needs one.
Old Apr 7, 2016 | 10:21 PM
  #335
foxxtrot82's Avatar
Car: 91 camaro z28
Axle/Gears: 323
my setup is stock, rear disc, 91 z28 350.
Last edited by foxxtrot82; Apr 7, 2016 at 10:22 PM. Reason: comma marks needed to be added for simplicity
Old Apr 22, 2016 | 12:30 PM
  #336
ILMODC's Avatar
OK, I gotta try this. I have a 1987 Trans Am with stock fronts and with what started out as drums in the back. I tossed on an axled that had disc. Not sure of year.
Any have a spring for sale? Not sure what Lbs. I'd need. Please advise as I'm close to having my LS Swap done and having extra braking force sounds kinda good.
Old Apr 23, 2016 | 11:27 AM
  #337
valicswarrior's Avatar
Car: 1985 Firebird S/E
Engine: SBC 350, mild cam Vortec heads
Transmission: Rebuilt 700R4 vette servo+shift kit
PM'd you
Old Apr 25, 2016 | 08:10 AM
  #338
ILMODC's Avatar
Replied! Thanks Valicswarrior!
Old Apr 29, 2016 | 02:50 PM
  #339
FJA1791's Avatar
Car: 1990 IROC-Z
Engine: 355/AFR 210
Transmission: POWERGLIDE
Axle/Gears: MOSER 12 BOLT 5.36 1/8 MILE ONLY
Having issue with rear brakes not working properly. I have a 1984 Z-28 L69 with factory J-65 brake option. Looking to improve the stopping power.
Anyone have a spring for sale? From what I've read looks like 22lb should be the correct spring. Please advise....Thank you, Frank
Old May 1, 2016 | 12:46 PM
  #340
Garth Knight's Avatar
Car: Firebird
Engine: 3.1 V6
I need one 1ncr5 (19 lb) and one 1ncf2 (22 lb). Anyone has both springs for a single shipment to Cleburne (TX) ?
Old May 1, 2016 | 10:40 PM
  #341
Ty92Z's Avatar
Engine: LB9 LO3
I have a couple 1NCF2s left if anyone needs one.
Old May 13, 2016 | 01:42 PM
  #342
Shane87irocz's Avatar
Car: 1987 IROC-Z
Engine: L-98 350 TPI
Looking to do this upgrade. I assume this works with 4wheel disc breaks on 87 iroc. I was looking at the spring from McMaster-Carr part num. 9435k123. Any info/ help is greatly appreciated! Thanks!
Old Jan 31, 2017 | 04:36 PM
  #343
ramicio's Avatar
Car: '87 Flame Red/Carmine Red GTA
I went with that 32.15 lbs. spring, and it locked up my rears in the wet last night when I barely had my foot on the brake pedal. The rear end coming around when one is trying to stop in certain conditions is not a good thing. I think I will drop it down to somewhere in the lower- to mid- 20 lbs. range.
Old Jan 31, 2017 | 05:18 PM
  #344
Napster134's Avatar
Car: 1991 Pontiac Firebird
Engine: 355 TBI
Transmission: 7004R
Axle/Gears: 3.27/42 ?
Just got a notification about someone slipping in the wet trying this mod out. I tried this out a few years ago. My car ended up in a dirt field after an unintentional 360 degree spin. Luckily, my car and I were OK. After that, I gave up on this mod and bought an adjustable proportioning valve. No problems since then.
For the sake of safety, your lives, and cars, I recommend an adjustable proportioning valve.
Old Feb 1, 2017 | 08:19 AM
  #345
BOTTLEDZ28's Avatar
Transmission: A4
There are many factor that come into play here regarding performance results from this mod.
I see a lot of guys doing the drum/disc swap but not bothering with the front brakes at all. Front brake hoses may be old and swelling. Pads may be those cheap Autozone "high performance ceramic" kind which dont work at all unless they are hot. All this things contribute to subpar front braking performance. Now, add in some 11"5" rear rotors, new rear pads, new rear hoses and you now have better brakes in the rear than the front. Add a few less than perfect road conditions and human error and the result can be loosing control of the car.
A LOT of people here have posted great results with this spring mod. I myself plan on doing this very mod in the next couple weeks. There is a spring that is a little less aggressive than the first one posted too.
Old Feb 2, 2017 | 11:55 PM
  #346
tglennon11's Avatar
Car: 87 IROC
Axle/Gears: LS1 10bolt w/ 3.73
the 1ncf1 spring? can you please report back how that one works? i saw that last week and was considering trying one myself.
Old Feb 5, 2017 | 10:49 PM
  #347
foxxtrot82's Avatar
Car: 91 camaro z28
Axle/Gears: 323
The spring allows more fluid to the rear wheels before cutting it off. I have to push my pedal hard for the rear wheels to stop. I believe most of us are referring to the rear disc brakes not applying much force. Cleaning the sliding pins seamed to help, considering it was dry on the inside. My rears only slid a little on dry pavement when purposely dry to lock them down multiple times. The fronts got a little spongy when hot, so that allowed the rears more responsibility to slow the car down. Havent tried on wet pavement. Buy the 1ncr5 and 1ncf2 from grainger. Theyre not that expensive. Its a heck of a lot cheaper than trying a new set of rear calipers. Prices are a little steap compared to the fronts. If you don't like it, you can always put factory back in. Experience can go a long way. I'm still glad I'm not the only one out there who has had this problem. Brake safely!
Old Feb 8, 2017 | 03:55 PM
  #348
Mikes86transam's Avatar
Car: 86 Trans AM LG4 5spd
I have an 87 Camaro that had drum rear brakes from the factory and I'm swapping in a disk brake rear with the aluminum calipers. Just to clarify I can swap the stock spring in the original proportioning valve with the 1ncr5 or 1ncf2 and it will work fine with the new rear disk brake setup? Picture is of the prop valve that's on my car now.
Old Feb 8, 2017 | 08:08 PM
  #349
daferris's Avatar
Car: One owner '88 IROC 50k
Engine: L98 with bolt ons.
Axle/Gears: 3:42 again
Yes you are correct. Just to give you a idea of how it works I have LS1 brakes on all 4 corners and with the 1ncf2 spring
and the car is almost perfectly balanced on the track. have had only 1 turn in 8 track days over the last 2 years and 2 sets of pads and rotors that the rear wanted to lock up 1st. Using the brakemotive slotted and drilled rotors and pads I could out brake anyone short of anyone with the carbon rotors. I did however have 1 out of 4 front rotors develop a crack from the drilled holes to the OD of the rotor...
The brakemotive stuff is so cheap I just replace the rotors and pads every year.
Also I do have 3 of the springs left if you want to PM me $5 shipped to anywhere in the lower 48...
Old Feb 18, 2017 | 04:30 PM
  #350
BOTTLEDZ28's Avatar
Transmission: A4
Looking for opinions here. I just did a drum to disc swap and used PBR calipers with stock Delco pads. I also used 13" Baer Eradispeed rotors. I have 3 options here for the proportioning valve.
1. swap in the 19lb spring (1ncr5) which I already have
or
2. swap in a complete valve from a disc/disc car of the same year as mine.
or
3. pull the spring and plunger out of the disc/disc valve and put it in my drum valve.
my original plan was to just do the srping mod but I found a disc/disc proportioning valve for under $50
