Brake lines rusted (Suggestions)
Car: 1986 Trans Am
Engine: lb9 305 tpi
Transmission: THM700R4
Axle/Gears: Posi-rear,3.27 9 bolt Borg Warner
Hi,I have an 86 trans am and the rust has eaten my undercarriage any suggestions on the brake lines i should get to replace them.
http://i851.photobucket.com/albums/a...e/DSC09237.jpg , http://i851.photobucket.com/albums/a...e/DSC09229.jpg , http://i851.photobucket.com/albums/a...e/DSC09235.jpg
Car: 1988 Camaro IROC-Z
Engine: L98 350/5.7 TPI
Axle/Gears: 2.77
Re: Brake lines rusted (Suggestions)
Judging by those pics, I wouldn't worry too much about that surface rust you have,
get that on any car if you use it daily or at least in the wet if it's not undersealed.
As for you brake lines, I'd just go standard unless you're looking for performance.
Car: 1986 Trans Am
Engine: lb9 305 tpi
The rust looks horrible. I'm afraid something's going to break or fall off. Do you know where i can get brake lines store or online?
www.inlinetube.com makes pre-molded stainless replacement brake lines. I have my eye on that as a potential "wish list" item as I restore my '84.
Car: 1986 Trans Am
Engine: lb9 305 tpi
Ah, thanks a lot! I'm restoring my 86 and i need it for a long road trip and i'm afraid the the brake lines,hoses, and gaskets are going to go from sitting in a garage for 13 yrs and not being started in that time. Btw Good luck with your restoration.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
