Drill & Slotted
Old Jan 28, 2011 | 09:58 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Drill & Slotted
89 camaro non-1LE with disk front drum rear, stock with 15" wheels.
Looking for drilled & slotted rear vented rotors for the front. Anyone know of a place where I could purchase them?
Old Jan 28, 2011 | 10:38 PM
hairysox33's Avatar
Re: Drill & Slotted
Summit Racing has them. Surface area is more important than heat dissipation. Think about it, how often are you baking full tilt on a road course? Bigger is better in a street car...
Old Jan 28, 2011 | 11:29 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Drill & Slotted
Not really, if you are already able to over power your tire of choice traction, bigger is a waste, they will just lock up earlier/easier.
Old Jan 29, 2011 | 07:29 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: Drill & Slotted
agreed.
I was talking to a performance guru in my town who builds stockcars and said that i should be looking for drilled and slotted rotors of the same size and have a 20-30% increase of stopping power when going 75 and braking or around town. he was explaining to me about my silly ideas of doing a c5 brake conversion and told me it would be pointless around town unless im going 100+ then it would be sensible. He was also talking to me about green brake pads (which i never heard of) and said I should look into that as well.
He said that the amount of surface area from being drilled and slotted its very minimal towards how much of the heat is actually being dispensed from burning up the brake pads. he said that it would even prolong the life on them. So he said that drilled slotted rear vented stock size rotors would be ideal.
So i was just checking if anyone else knew where to get them. Thanks for the tid bit also on summit, ill check there!
Old Jan 29, 2011 | 07:31 PM
hairysox33's Avatar
Re: Drill & Slotted
Apparently I was the one who was misinformed
Old Jan 29, 2011 | 08:27 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Drill & Slotted
driller rotors have a tendency to crack, so i dont see what this "guru" thinks they are so great.
good replacement blanks and a set of good pads, like hawks pads or similar will get you more performance, without the cracking issues of a drilled rotor.
besides, you are loosing surface area because of the holes and slots, on a rotor thats already too small to begin with.
FWIW, i put a set of drilled and slotted stock type rotors on my 86 years ago and noticed absolutly no difference at all.
Old Jan 29, 2011 | 10:41 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Drill & Slotted
Well consider this [and im only half screwing with ya] if you have no trouble locking up the tires with all stock blank stuff, then drill n slotted should stop better as its not gonna lock up as easy if the loss of surface area matters.
If that is so, it should take more brake pressure to lock them, as locked up tires don't stop as well and thus drill n slotted would stop better.
Old Jan 30, 2011 | 09:19 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: Drill & Slotted
well, thats a different way of looking at it, and, in all reality, probably correct.
however, ease of locking up brakes is no indication of their performance.
for the op, its up to you, but the drilled and slotted will not provide any gain you will notice over a set of blanks. Just buy quality parts and good pads, even ACDelco pads are pretty good, and you will be fine.
Old Jan 30, 2011 | 09:55 AM
hairysox33's Avatar
Re: Drill & Slotted
It would be interesting to do a side by side comparison of stock size drilled/slotted vs. stock vs. bigger....
Old Jan 30, 2011 | 11:57 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Re: Drill & Slotted
So instead of getting better tires, adjusting brake bias, getting newer shocks/struts (all things you can do to reduce the likelihood of lockup) you want to reduce braking power and reduce rotor life? Maybe it's just me but going about it that way seems backassward.
Honestly though, in a street application I doubt you'll notice a difference with drilled/slotted. Unless you like to beat the crap out of your car all the time and then you're just going to kill the life.
Old Jan 30, 2011 | 05:08 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Drill & Slotted
Nope thats my whole point, if you can over powers your tires all stock, what's the point of bigger brakes.
Just slappin on bigger stuff won't help if you don't address the other issue.
It all comes down to that 5x5 section of tire that meets the ground.
Old Jan 30, 2011 | 05:50 PM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Re: Drill & Slotted
Getting back to the original question, SSBC makes a rotor for our cars that is drilled and slotted...
Old Jan 30, 2011 | 06:52 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
Re: Drill & Slotted
the drilled and slotted rotors run cooler. they get the hot gas and dust. away from the face of the rotor. has for the cracking..lol. well. even the face of undrilled rotors can crack. (iv seen them) but with the camfer its a thing of the past with ss brake lines 2 piston calipers and drilled and slotted 10.5 rotors. my Z28 stops on a dime.
no need for bigger brakes. but thats just me.
i have them all the way around. and can brake with my big toe..
Old Jan 30, 2011 | 07:00 PM
J91's Avatar
J91
Re: Drill & Slotted
Running the same setup, it does work great....
Old Jan 30, 2011 | 11:03 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: Drill & Slotted
thanks!
What is this setup? I understand it but is it a kit i can purchase?
Old Jan 31, 2011 | 01:16 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Re: Drill & Slotted
So again, instead of improving the rest of the system you want to downgrade already inadequate brakes? This makes perfect sense.
And yes, I just said the contact patch hitting the pavement has a huge affect on braking distance.
Old Jan 31, 2011 | 01:20 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Re: Drill & Slotted
Modern pads gassing is almost non-existant. Yes blanks can crack. From overheating. If that's the case then duct some air in there. Take a step forward, not a step back. I've cracked my 14" z06 rotors but I beat the snot out of my daily driver.
Old Jan 31, 2011 | 06:45 AM
J91's Avatar
J91
Re: Drill & Slotted
Originally Posted by Timinsk
thanks!
Bo to ssbc.com, the caliper kit is a A181, several rotor choices are available, search the site, don't know the exact model no. All the parts are available through Jegs or Summit...
http://www.ssbrakes.com/commerce/bra...s%20%26%20Pads
Old Jan 31, 2011 | 01:59 PM
Guest
Guest
Posts: n/a
Re: Drill & Slotted
There is a use for everything, including cross drilled rotors. The holes themselves add area for heat dissipation, and airflow. They also reduce swept area, so braking force is reduced to a degree. On the stock brakes, if you were to cross drill one side and not the other, you could find out that they definitely run a lot cooler and that the car will pull under braking from the loss of swept area.
That said, with how most people use brakes and supply an adequate amount of cooling and tread on their cars they're mostly if not entirely cosmetic in nature.
Old Feb 3, 2011 | 10:20 AM
Andrew91GT's Avatar
Car: 1990 formula
Engine: 433 sbf + turbos
Transmission: powerglide
Axle/Gears: fab9, 3.50
Re: Drill & Slotted
agreed.
Why wouldn't you do a c5 brake conversion?
Old Feb 3, 2011 | 05:39 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: Drill & Slotted
the amount of money for the conversion and actually purpose for needs for it is pointless
Old Feb 3, 2011 | 08:35 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Re: Drill & Slotted
Old Feb 5, 2011 | 01:01 AM
Re: Drill & Slotted
ssbc calprs $435 summit alum 2 piston alum finnish
drilled slotted rotors with cramic pads $200 shipped R1 concps
wheel bearings $35
ss brake lines summit/russl forget what i paid (4 wheel disk set)
stops my 10 sec camaro just fine. but yet agen..thats just me
Old Feb 5, 2011 | 03:08 AM
J91's Avatar
J91
Re: Drill & Slotted
wheel bearings $35
Got mine @ Jegs for a little less. The calipers came w/ the Russel braided lines....
Old Feb 5, 2011 | 04:06 AM
Re: Drill & Slotted
my ss brake line set is the 5 pc. dont have any rubber lines left on the car.I do like my drilled and sloted rotors also
Old Feb 5, 2011 | 04:58 AM
the solitaire's Avatar
Car: '89 RS camaro 305 TBI
Engine: LO3
Axle/Gears: yep, has those too (stock)
Re: Drill & Slotted
I have a set of EBC slotted and drilled brake rotors on the front, as well as a set of EBC red stuff pads.
This along with the 1LE calipers made a considerable difference compared to the stock brakes, but the difference is mainly noticable after building up some temperature, at which point the blank brakes started to fade and the slotted ones don´t.
Drilled pads do not quite make as much sense for street use. Slotted actually do, especially with rather heavy cars. Slotted and/or drilled brakes do increase wear on pads and rotors considerably.
Old Feb 5, 2011 | 12:21 PM
Camaro305SB's Avatar
Car: 87 Camaro
Engine: 305 LG4 (H)
Re: Drill & Slotted
Thats funny coming from someone who wants slotted and drilled rotors on his stock 305 Camaro.
Old Feb 5, 2011 | 12:24 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Re: Drill & Slotted
wheel bearings $35
How many times do you stop the brake pedal on the dragstrip? Once.
Old Feb 5, 2011 | 12:35 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: Drill & Slotted
consideringive read the odds and its now pointless that i notice it.
Old Feb 5, 2011 | 10:15 PM
Andrew91GT's Avatar
Car: 1990 formula
Re: Drill & Slotted
I got c5 calipers and brackets, front and rear eradispeed rotors, hawk pads and stainless lines for $350 plus the ride.
Had to buy ed's brackets but overall not really that expensive.
Old Feb 5, 2011 | 10:22 PM
Re: Drill & Slotted
2 to 3 times. then make the turn. then get back on it (return) lane race..lol. and when im driving it on the street. they also stop the car just fine. but then im not driving like the Dukes Of Hazard. just your every day 3300lb 10.20 sec street car.
Old Feb 7, 2011 | 06:36 AM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: Drill & Slotted
the prices ive been coming up with are about 750$+ for c5 kit
Old Feb 7, 2011 | 10:13 AM
Verhagen82's Avatar
Car: 82 Firebird
Engine: Boosted LSX
Transmission: Built 4L60E
Axle/Gears: 4th Gen 3.42s
Re: Drill & Slotted
ebay. you can find all of the name brands if you dont want to go cheap although the ebay brands are just fine when it comes to rotors
Old Feb 7, 2011 | 08:01 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: Drill & Slotted
i pieced together my c5 setup for under 500 bux off ebay and here, complete, spindles, hubs, brackets, calipers and abutments, new rotors, and pads.
if you look around, and keep an eye out, great deals pop up from time to time.
but of course, if you are sticking with 15" wheels, your options are more limited
Old Feb 8, 2011 | 05:24 AM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: Drill & Slotted
I have 17" c6 oereplica
i just never trusted ebay...
Old Feb 8, 2011 | 06:05 AM
MotorMouth's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Re: Drill & Slotted
I have a set that came in a kit Raybestos Quiet Stop Ceramic Brake Pads, cross drilled and slotted rotors and calipers. They have lasted for 10 years. You can't turn them once you need to do that you have to replace them. As long as you torque the lugs to the correct amount they will last. I seen a huge difference in my stopping distance it was like night and day.
Old Apr 3, 2011 | 11:28 AM
chrispy383's Avatar
Car: 92 rs 25th ann.
Engine: 383
Axle/Gears: 342
Re: Drill & Slotted
Summit racing has a pad and rotor kit rotors are slotted and dimpled insted of drilled, pads are ceramic. Part # sum-kar8213ps $207.90
Old Apr 3, 2011 | 02:32 PM
Re: Drill & Slotted
wilwood billet single piston calip $98 ea (stock fitment)
ss brake line for the front $61.00 For above.
R1 drlled rotors front & back $200
ss brake lines for the back $100
this is for the front none 1LE
with 10.5 rotors
calipers $196 SET Wilwood
rotors with crmc pads $200 4 PC SET zink plate us made
ss brake lines $61.00 2 PC SET Wilwood
you can buy over time or all at the same time..
this also drops off anther 6lbs from the front of the car.
stopping your 3300lb 10 sec street car camaro with 4" wide front tires
PRICELESS!
Old May 29, 2011 | 04:13 PM
Re: Drill & Slotted
remember:
if you want to add billet alum calipers Wilwood makes them
$98ea from summit
metric 120-7197 part # if i remember right
and you will drop off another 6 / 7 LBS off the car
Old Jun 8, 2011 | 05:33 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: Drill & Slotted
Here's a article addressing this same subject that I thought was interesting.
http://reviews.ebay.com/Drilled-vs-s...00000005243690
Old Jun 8, 2011 | 06:07 PM
J91's Avatar
J91
Re: Drill & Slotted
Interesting, informative, Thx...
Old Jun 9, 2011 | 08:19 PM
  #42
GICATA's Avatar
Car: '83 WS6 T/A 65,000 miles
Engine: 5.0L vin H stock, 406SBC right now
Axle/Gears: Corp. 3.73
Re: Drill & Slotted
I was thinking as I was reading all the posts...hmmm, Mercedes/Porsche uses drilled rotors, they can't be that bad, and then I read the attached article and there at the bottom are the mfgs listed that I sell brakes for!
"...I believe that drilled rotors are better for street and highway driving. For most drivers, I recommend drilled rotors over slotted rotors, and this conclusion is supported by the fact that Corvette, Ford GT, Porsche, Mercedes and BMW come with OEM drilled rotors..."
...along with several other mfgs. Glad I bought drilled rotors for my car.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Veaceonee
Sep 29, 2016 08:15 PM
84 TA NV
Sep 6, 2015 08:02 PM
Third_Gens_Rule
Sep 3, 2015 06:56 PM
Third_Gens_Rule
Sep 3, 2015 06:55 PM
