Need help routing hard lines on 10 bolt disc conversion
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
I'm hopefully going to pretty much get my drum to disc conversion done on a second axle I bought but was trying to figure out how the hard lines go and I can't work it out. One is longer than the other, but just can't see how the things sit. Does anyone have a picture?
Cheers.
Cheers.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Need help routing hard lines on 10 bolt disc conversion
Pretty much the same way as it is on a drum rear.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
longer one goes to pass side, shorter one to driver side. there's a rubber hose from body to axle, runs to a T fitting, then the hard lines split off the T, to driver side and pass side
Car: 1990 Camaro RS
Axle/Gears: 10 bolt, 3.73 Ratio, Torsen LSD
what kind of disk breaks? I just did a rear LS brake swap (very little clearance with my 15"s lol).
Car: 1992 RS
Engine: Carbed 350
Yikes! My 15's wouldn't fit at all on my LS1 brakes - are you sure you have LS1 brakes and not LT1?
Car: 1990 Camaro RS
Positive. There under after market rims. There like an aluminum drag style rim. I don't think LS brakes would fit under stock 15"s. And the clearance is very close like I said. I might take a pic later and put it up.
Car: 87 IROC
Engine: modded LB9
Thanks, think I've figured it out now I know which length goes to which side.
Got other issues though that I'll post in a new thread.
hectre13
Dec 11, 2023 08:14 AM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
ambainb
Apr 25, 2016 09:21 PM
sailtexas186548
Jan 19, 2016 12:21 PM
