C4 Brake bracket to spindle torque spec
Old Apr 15, 2011 | 09:54 PM
L695speed's Avatar
Car: '88 Trans Am GTA; '84 Trans Am
Engine: L98 350TPI; 5.3 LSx built
Transmission: N/A; T56
Axle/Gears: 3.70 9 bolt; 3.73 10 bolt
As stated in the title. What are the torque specs for the C4 bracket to spindle bolts used on C4 brake conversions? Thanks.
Old Apr 15, 2011 | 09:59 PM
L695speed's Avatar
Re: C4 Brake bracket to spindle torque spec
I just remembered the Lukestaff site. Says 89 Ft lbs for the torque spec. Sound about right to you guys? I'm gonna go ahead and put that spec on the bolts, unless someone says different.
Old Apr 16, 2011 | 07:28 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
That's the spec for 1LE's as well, if that info is worth anything.
JamesC
Old Apr 16, 2011 | 08:44 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I would use the torque spec for the bolt being used. There may be two different size bolts depending upon what was used/supplied. Be sure to use red loctite on the bracket to spindle bolts. And blue locktite on the abutment to bracket bolts.
RBob.
Old Apr 16, 2011 | 09:02 AM
JamesC's Avatar
Will the use of Loctite change the spec?
JamesC
Old Apr 16, 2011 | 12:09 PM
L695speed's Avatar
JamesC
According to the Lukeskaff site, it does. said 89 without the loctite and 83 with it. These are for the fronts, not the PBR rears. That I already know thanks to you James. Bolts are the same size just different lengths. I just wanted to be sure that it wasn't like 30 before I did it. I don't think I've ever used loctite on much anything. If I did then I don't remember doing so. But if its better to use it on these things then maybe I'll do just that and torque em to 83.
And RBob, when you say abutment... are you talking about the carrier? I don't have the calipers and rotors etc. yet, and I still need to order hubs and bearings as well.
Old Apr 16, 2011 | 02:12 PM
JamesC's Avatar
That number was for the fronts. My 91 Bird shop manual confirms 89 for the 1LE.
JamesC
Old Apr 16, 2011 | 03:25 PM
L695speed's Avatar
JamesC
Ok James, 89 it is. Thanks for the double check.
1992 Trans Am
May 10, 2023 07:19 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Genopsyde
Nov 11, 2015 10:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
