Greasing the Calipers
Old May 2, 2011 | 12:56 PM
jimidude87's Avatar
So I went out this morning to grease everything in my car because it sat for 2 years before I bought it. I got the wheels off and greased the back drum and then went to grease the front caliper. I couldn't get the grease gun on the valve. Do I have to take the calipers off the rotor in order to grease this or is there a trick I have to do (like turning the wheel a certain way or something stupid like that). Thanks guys
1990 camaro rs 5 speed
Old May 2, 2011 | 01:01 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Greasing the Calipers
There's no grease fittings on the brake system. You're trying to pump grease into the bleeder screws.
Old May 2, 2011 | 01:16 PM
jimidude87's Avatar
Ok that makes sense...so now my question is there a way to grease the pins that the calipers slide on? the guy that had it before me sprayed some white lithium grease on it but that just doesn't seem like it would be safe or long lasting
Old May 2, 2011 | 01:19 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yes, you take the pins out, grease everything, and then put it back together.
Old May 2, 2011 | 01:54 PM
blackbmagic's Avatar
Car: 1985 IROC-Z
Engine: 355
Axle/Gears: 3.42 10 Bolt Posi
that made me laugh.
Yea use specific brake grease usually synthetic grease, clear with a flourescent hue. Just the pins and contact points on caliper and pad. Judging from your first post. NO GREASE ON DISC, DRUMS OR PAD FACES.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
BADNBLK
Brakes
Oct 6, 2015 02:51 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
the_hamturdler
Sep 30, 2015 12:50 PM
