1LE guys
Old May 9, 2011 | 11:02 AM
Realmac4's Avatar
Car: 1991 Z-28/ '94 Impala SS
Engine: 355 TPI/ 350 LT-1
Transmission: T-56 in both
Axle/Gears: 3.73 / 4.56
1LE guys
What brand of pad are you running? I have them and am doing the 13 in Vette rotor upgrade. I would like to try Hawks. Just looking for some input.
Old May 9, 2011 | 11:05 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 1LE guys
Hawks, front and rear, for me.
JamesC
Old May 9, 2011 | 11:28 AM
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
Axle/Gears: 3.42 T2R
Re: 1LE guys
I run Porterfield R4 (race pad) on my 1le equiped racecar.
I just installed some R4-S (their street pad) on my '02 T/A streetcar this past Sunday, so no feedback on those yet.
Old May 9, 2011 | 12:21 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
Re: 1LE guys
HAWK HPS
tell me more about this 13" rotor upgrade, whats needed?
Old May 9, 2011 | 12:43 PM
JamesC's Avatar
Re: 1LE guys
I'm assuming the OP is speaking of the rears--at least I'm unfamiliar with a 1LE front upgrade of that nature.
JamesC
Old May 9, 2011 | 02:50 PM
Realmac4's Avatar
Re: 1LE guys
Check with EB Miller, you can use your 1 LE caliper, different abuntment brackets and hubs, and install a 13 in HD Vette rotor.
Old May 9, 2011 | 03:27 PM
JamesC's Avatar
Re: 1LE guys
Ah, here we go:
http://www.flynbye.com/catalog/i17.html
Thanks for the heads-up. So essentially the rotor is simply larger. I wonder how much real world difference that would make?
JamesC
Old May 9, 2011 | 09:33 PM
91 1LE's Avatar
Car: '91 1LE
Engine: 377 w/Stealthram
Axle/Gears: 3.42 Torsen
Re: 1LE guys
I'm guessing it would be a noticable difference. Any time you can move the caliper farther away from the spindle with a larger rotor you increase leverage. The farther you get the faster that portion of the rotor is traveling and there is also an increase of surface area.
Old May 9, 2011 | 10:22 PM
KiLLJ0Y's Avatar
Engine: 4.3 Turbo
Transmission: 4L60
Re: 1LE guys
shoot.. for almost a $1000 for another 1"... not worth it to me
Old May 10, 2011 | 06:33 AM
Realmac4's Avatar
Re: 1LE guys
No-No, I already have the 1LE set-up, all you need is the hubs, brackets, and rotors. And I found a good deal from a place, rotorpros, and got dimpled/slotted 13 in front and 12 rear LS car(For the rear drum to disc swap) for $200 shipped for all four. Now that is pretty cheap, and the car is not a big auto-x or track car, so they should hold up to some street driving, and they came recommended from my guys on the caddie (CTS-V LS-6) board.
Once I am all together I will let you know how they hold up.
Old May 11, 2011 | 01:24 PM
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
Re: 1LE guys
I'd be curious about this. Yes it may have more leverage, but at what expense? I can see there being less pad life, and the pads getting hotter than usual since that part of the rotor is moving faster (albiet fairly slightly). There is no (pad to rotor contact) increase in surface area.
Old May 11, 2011 | 10:15 PM
91 1LE's Avatar
Car: '91 1LE
Re: 1LE guys
I think pad life would be exactly the same. The vehicle travelling at a given speed requires a set amount of energy (heat/friction) to stop it. With the increased rotor size this heat is applied to a larger area of the rotor which will help with fade resistance. And given that the outer edge of the larger rotor is moving faster, there is less pad force(per amount of time) required as the distance the pad scrubs on the rotor is longer, comparing equal speed stops. Mechanically speaking it is less "work" for the caliper/pad with the larger rotors. The benefit being is if you wanted to make a faster stop, the larger rotor will have more braking force before locking up.
Vintageracer
Jan 10, 2020 05:33 PM
aaron7
Aug 17, 2016 06:02 PM
gta90
Sep 15, 2015 04:00 PM
Street Lethal
Aug 14, 2015 08:25 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
