C5 Front brakes...Dedicated thread?
Car: 1967 Firebird P.T.
Engine: LS3 4" Strkr 422ci
Transmission: MN12 6 speed
Axle/Gears: 3.73 8.5" 10 Bolt Eaton
Honestly ive searched for about 45 minutes, i cant find the thread that has all the diameters and measurements for the mods to convert to C5 front brakes, like what the hub needs to be machined to (5.95 inches??) Isnt there a dedicated thread on that conversion?
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: C5 Front brakes...Dedicated thread?
James i looked at that site 3 times now and he states "For C4 and C4 HD upgraded take the hub down to 5.95 inches diameter." is it the same for C5?
i read through this thread on LS1 brakes:
https://www.thirdgen.org/forums/faq-...s1-brakes.html
and found this:
Q: What outer diameter should I take hub down to?
A: You should take the LS1 rotor with you to the machine shop and have them machine down the hub until it fits in the hat of the LS1 rotor. My hubs have an outer diameter of 5.85 inches.
so now i have two different measurements on the hub, does anyone know what the stock f-body rotor/hub has to be machined to in diameter for the C5 conversion? JamesC? Fueled Soul? -OR- are they all different judging by what that says above about bring the rotor with you? no set standard?
and found this:
Car: 1992 Camaro RS 25th Anniversary
Engine: Stock 305 TBI, LT1 soon.
Transmission: V6 NWC T5 by choice
Axle/Gears: Zexel Torsen LSD with 3.23's
I'm not sure of the exact diameter of the hubs, but IIRC, the inner section of the stock C5 rotor tapers from the inside face to the walls like a trapezoid. I didn't machine the hubs' side down, instead, I ground off the outer edge of the hub until the face sat flush with the inner face of the rotor. Essentially, the hub went from square to trapezoidal. However, if you're already getting the hubs machined to take the 10.5" section off, then maybe you can get them machined to size.
You can buy a full kit off http://www.kore3.com/products.php?cat=11 or just the hubs if you want.
and mike thanks for the reply, i remember the rotors have that odd trapezoid shape now, ill just bring both down to the machine shop and have them machine it to match. Thanks
Car: 85 Camaro
Engine: 454 RamJet
Transmission: 4L80e
Axle/Gears: C5 IRS
I bought all the brake components from ebay for about $200, machined my own brackets( I would just buy them from ebay or FLYNBYE now), also purchased my hubs from a tgo member( again was planning on buying them from flynbye)
http://flynbye.com/catalog/c1_p5.html
Between ebay, Kore3, and bigbrakeupgrade.com, I put my setup together front and rear for under 1k. Front C5 rotors and brackets with 2006 GTO calipers and rear LS1 brakes. Kore3 supplied my braided steel hoses.
Street Lethal
Apr 30, 2019 12:14 PM
Linson
Aug 21, 2015 02:12 PM
