Early design 89 prop valve question
Old May 16, 2011 | 05:09 PM
lonesomeloser's Avatar
Car: 1983 Z28
Went to install it today but on the new valve there is a "block-off" with a black cap on the very front of it. Well, this is where the rear brake line attaches the the one in my car now. So my question is, do I have to remove the cap and such, and place all that in the unused port, or do I bend the brake line to screw into the underside of the new valve? I was told this is a direct fit.
Old May 16, 2011 | 05:40 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Early design 89 prop valve question
It sounds as if your 85 is equipped with the old-style cast iron version of the combination valve. Most were SAE, but I have seen reports where the 85's were metric as well. At any rate be cautious when threading. Check posts #1 and 2 for pics. If you have the old style, you'll have to do some line bending.
https://www.thirdgen.org/forums/brak...rop-valve.html
JamesC
Old May 16, 2011 | 05:56 PM
Car: 1983 Z28
Yes it's the old style, and I haven't tried the threads yet. What is the best way to bend the brake line? Right now there 2 loops in the line where it attaches to the front. Should I have those removed? Or bend the line downstream?
69 Six Pack
Oct 5, 2015 07:51 PM
Cameeeero
Sep 18, 2015 04:00 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
redmaroz
Aug 16, 2015 11:40 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
