brake booster removal
Old Jun 24, 2011 | 08:27 PM
89RESTO's Avatar
2011 Norwood Gathering
ThirdGen Camaro Rep
Car: 1989 IROC
Engine: 5.7
Axle/Gears: 9 bolt 2:77
Do I have to tear my dash apart to remove the brake booster? I'm painting the engine bay on my IROC and really don't feel like tearing the dash out. Any help is appreciated. Thanks
Old Jun 24, 2011 | 08:54 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: brake booster removal
if you remove the under dash panel, you can get to the bolts, its a PITA, but totally do-able.
Old Jun 24, 2011 | 09:07 PM
89RESTO's Avatar
ThirdGen Camaro Rep
Car: 1989 IROC
Engine: 5.7
If It's just a matter of removing the kick panel that sounds doable, I just didn't want to remove the dash pad,gauges drop the steering column Etc... Thanks for the quick reply.
Old Jun 24, 2011 | 10:02 PM
It's not a PITA at all; doesn't take 5 minutes, even for a complete moron and slowpoke like me. Somebody smart and quick like you can probably do it ALOT quicker. Total piece o cake.
Old Jun 25, 2011 | 07:07 AM
89RESTO's Avatar
ThirdGen Camaro Rep
Car: 1989 IROC
Engine: 5.7
I hope your not calling me "smart and quick", Obviously you've never spoken to my wife , lol. Thanks again for the help.
Old Jun 25, 2011 | 10:02 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
seriously, i wont call this a piece of cake, it takes some time. totally do-able, but not a cake walk. bottom 2 bolts are pretty simple, but the upper 2 are buried by various linkages and cables/wires, so they take a little more time.
Old Jun 25, 2011 | 04:18 PM
89RESTO's Avatar
ThirdGen Camaro Rep
Car: 1989 IROC
Engine: 5.7
Well I got it off, I would classify it as a PITA. The drivers side no problem but the top right was very difficult, because the studs are so long you need to use a deep well socket, and then you need a universal joint and an extension, because of the extreme angle it's very difficult to turn the ratchet more than a half turn before the u-joint locks up.I gave up and used the air ratchet to overcome the binding of the u-joint.
I think I'm going to replace it while I have it out, I wouldn't want to do that again!!! Getting to darn old and don't bend like that anymore.one more thing to add in case someone is reading this in the future it helps to drop the steering column.
Old Jun 26, 2011 | 09:15 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
it also depends on the year of the car. its a nightmare to remove the booster on my 86, for whatever reason it has a lot more crap stuffed up around the steering column. Had to drop the column a bit and use a bunch of extensions to remove the top bolts.. my 92 on the other hard, was pretty straight forward, and i would reach everything from under the dash with little drama.
Vintageracer
Jan 10, 2020 05:33 PM
Eric-86sc
Apr 3, 2016 03:52 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
3rdgenparts
Aug 8, 2015 07:09 PM
