how to bleed the brakes with pbr and iron calipers
Old Jul 7, 2011 | 06:33 PM
the rookie24's Avatar
Car: 1992 rs stock for now
Transmission: auto
i jus installed a 9 bolt in my 92 rs the rear as the iron delco brakes and the front are the aluminum how do i bleed the system i need help asap thanks
Old Jul 7, 2011 | 06:36 PM
Re: how to bleed the brakes with pbr and iron calipers
By opening each of the bleeder screws and letting the air out, one wheel at a time, starting with the one farthest from the master cyl. Make sure you don't let the MC run dry because otherwise you'll have to take it off and bench bleed it.
The air does not care which type of calipers it is stuck in, or even, if it's stuck in little cylinders instead of calipers. It all works the same way.
83 Crossfire TA
Jan 3, 2016 01:26 PM
dbrochard
Oct 3, 2015 12:43 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
rudolphschenker
Sep 4, 2015 02:41 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
