Who can mod hubs for an LS brake swap?!
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
Cause I've been having a very hard time finding any place that can do it! I didn't think it'd be this much of an issue....
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: Who can mod hubs for an LS brake swap?!
I had my C5 hubs machined down by a guy who runs a 4X4 shop out of his own garage. He said anyone with a brake lathe could do it if they knew what they were doing. Cost me 2 hrs labor, but worth it to me.
Car: '91 LS6/T56/9"
Engine: LS6
That's exactly what I'm thinking, but everyone's a idiot in Chicago.
Car: 1987 Trans Am
Engine: LQ9/L92
i just found myself a machine shop locally, doesn't have to be someone car-related. i dug through the yellow pages and called about a dozen places before i found someone, but they're done now. came out a little on the high side ($90), but they're done and finally on the car
Car: 83 Z28
Engine: F-body LT1 swap
Transmission: T-56 swap
Axle/Gears: 10 bolt w/ 28 spl posi, 4.10, disks
I did it myself on a brake lathe in about two hours.
Cut the hats off with a cut-off wheel, then find someone to turn them down for you.
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i could find someone for you, but it'll be south side if you want it done.
Car: 1984 Z28
also you need the studs pressed in before you have them machined down or they may crack afterwards, so i'd have the same machine shop do that as well
Car: '91 LS6/T56/9"
Engine: LS6
How would they crack? Maybe if you cut them WAYYY to close to the holes, but otherwise mine are 5.77" exactly the same diameter as the stock LS hubs. I've never heard of someone cracking a hub just by installing new studs. What makes you say they could crack?
Car: '91 LS6/T56/9"
Engine: LS6
Came out awesome! Mic'd at 5.77" which is exactly what the LS1 hub measures. Here's what they looked like when I got home with them tonight:
Here's after I cleaned them up:
And here's after paint:
