Front PBR caliper banjo bolt problem
Car: 1989 GTA
Engine: 5.7L
Axle/Gears: 3.27 BW 9-bolt
I am converting my '89 GTA to a 1LE front brake setup. The install went fine up until I attempted to attach the brake hose to the driver's side caliper. The supplied banjo bolt bottoms out in the caliper before the hose fitting is secured. The crush washers are about 1/16" away from even touching the caliper and the banjo bolt. The same banjo bolt works fine on the passenger side caliper, and the hose on that side installed without any problems. Comparing the inside of the banjo bolt holes on the driver's and passenger's side calipers, the driver's side hole is much shallower than the passenger's side. Is this normal? Does the driver's side take a different banjo bolt? Or is it just a bad caliper? What is the length of the correct banjo bolt?
Car: 87 T/A
Engine: TPI 350 ci
Transmission: 5 speed
... when I did the conversion a couple of years ago, I didn't run into that problem. Confirming there is a 'crush' washer on both sides the hose, between caliper and hose and hose and bolt?
Car: 1989 GTA
Engine: 5.7L
I used one new crush washer on each side of the hose fitting as usual. The right side went together fine. The hole depth was noticably different between the two calipers. The bolt is probably 1/4" too long to fully seat the fitting. I am considering getting another caliper to look at. If that doesn't work then I guess I'll try to find another banjo bolt. These are the bolts that came with the Spohn kit so I'd be surprised if they didn't work.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Not that this info will assist, but I upgraded with the Spohn kit and all went together without difficulty. Contact Spohn. My experience is that'll he take care of matters.
JamesC
JamesC
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I'd call Steve also. I've messed with the banjos for C4, 1LE, and C5 and there's only a slight difference between them. They all thread the same so I don't know what could be wrong.
Ed
Ed
Car: 1989 GTA
Engine: 5.7L
The problem turned out to be a bad caliper. I got another one at AutoZone today and it was fine. I'm not very happy about turning in the other new caliper for a core.
Should have got with me, I 've got a few on hand and we could have worked something out...hate to hear you had to return a new caliper.
Ed
Ed
Car: 55 chevy Belair & 86IROC Z
Engine: 350 in 55 86IROC Z LT1
Transmission: 55 4speed IROC Z4L60e
Axle/Gears: 12 bolt 410 in55 and 342 inCamaro
Re: Front PBR caliper banjo bolt problem
I am replacing the rear brake pads and rotor and left left caliper started leaking i replaced the hard line with stainless braided hose and used the old brass block where banjo bolt go's it does fit right like the bolt too short is there longer banjo bolts I got new from autozone same thing help
Eric-86sc
Apr 3, 2016 03:52 PM
sailtexas186548
Jan 19, 2016 12:21 PM
