need help about locking front brakes.
Old Aug 4, 2011 | 02:30 PM
bensbaby's Avatar
Car: 1988 GTA Trans am 1 owner since new
Engine: 383 built
Transmission: 1995 camaro t56 6 speed
Axle/Gears: 3.24 posi 9 bolt
I need some help.
I have a 88 gta 5.0 l 5 speed.
the car was in storage for 2 years...it was mint brakes no pulling before i put it away...i got it out this spring and its like i have no brakes.
i touch the brake peadal and the car slams to the right hardddd and i have to grab the wheel to correct it.
i am a mechanic so i figured siezed driverside front caliper.
i bought a new one and it was siezed up a bit .
it fixed a bit of it but still doing it.
i am gonna change the other front caliper this afternoon.
could it be the brake flex hoses shrunk down and are causing this to lock even after i installed a new caliper??
could it be a prop valve is it hard to change one where is it??
i just have std front calipers...and disc brakes on the rear.
the ebrake works.
it just seems like its a seized driverside caliper even tho i changed it.
pls help
Old Aug 4, 2011 | 02:45 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: need help about locking front brakes.
Originally Posted by bensbaby
could it be the brake flex hoses....
Very likely. The problem is common in our cars. Replacing both sides at the same time is the best bet.
JamesC
Old Aug 4, 2011 | 07:28 PM
UK Speedbird's Avatar
Car: 91 Firebird
Engine: 3.1L 191ci
JamesC
Couldn't agree more. I had a problem with my Transit van, as you came to a stop you could feel as though one brake was dragging even though your foot was off the brake.
I made the mistake of changing both calipers as I felt there the problem lie.
Turned out it was the brake hose that was blocked and not letting fluid back out of the caliper!
Lesson : start with the easy and less expensive stuff first!
Speed.
Old Aug 5, 2011 | 12:18 PM
bensbaby's Avatar
Engine: 383 built
i changed them all last night and mint....the driverside was pluged solid i could blow air through it...and the passenger was half plugged.
new hoses and new front calipers and bam brakes are better than ever ....thanks again.
should i be changing the rears?????????
Old Aug 5, 2011 | 12:36 PM
JamesC's Avatar
Since those hoses are 20+ years old, I'd throw new ones in.
JamesC
Old Aug 10, 2011 | 07:46 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
agreed. such a small price to pay for safety. also check the color of your brake fluid; if its dark, it's sucked up moisture (very common) and it needs to be changed.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
