brake line diagram?
Car: 1991 Camaro RS
Engine: 305tbi
brake line diagram?
I am looking for a diagram for my 1991 camaro's brake line system and can not find one. I really want to know what lines go into the different ports on the proportioning valve cause the stock valve is not marked. I have an adjustable valve that is marked but do not know what line is what. If anyone has the answer that would help out a lot.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: brake line diagram?
seriously? perhaps look at it? Sorry to be a little blunt, but 2 minutes looking at the valve will give you a good idea where the lines go.
your adjustable valve will be plumbed into the front line, 1/4" (6mm) OD, thats be rear brakes.
