Post your brake upgrade pics here!
Old Sep 18, 2011 | 01:52 AM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Since I've seen there's a thread for almost everything I thought we should have one for brake upgrades as well. Unless there isnone already on here. So post your brakes pics and lets see what everyone has .
Old Oct 28, 2011 | 03:08 AM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: Post your brake upgrade pics here!
Anyone?
Old Oct 28, 2011 | 05:39 AM
fast377's Avatar
Car: 91 Z28
Transmission: t-56
Axle/Gears: 3.73 4th gen 10 bolt
Old Oct 28, 2011 | 10:38 AM
robguitargod1's Avatar
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
Started with front and rear LS1 Camaro brakes. $350 for everything shipped to my door.
ugly fronts:
spindle before modding:
front calipers before cleaning/painting:
painting:
making hubs:
Old Oct 28, 2011 | 10:39 AM
Car: '91 LS6/T56/9"
Engine: LS6
spindles powdercoated:
hubs done:
bracket installed:
done:
Old Oct 28, 2011 | 10:46 AM
Car: '91 LS6/T56/9"
Engine: LS6
Rears:
LS rears blown apart:
adj proportioning valve installed:
after drums removed:
cutting/drilling:
making parking brake cables:
https://www.thirdgen.org/forums/brak...-ls1-swap.html
done:Name:  DSCF5286.jpg
Old Oct 28, 2011 | 04:29 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Thanks for posting pics you guys. Waiting to see some one with the 5th gen brakes to see how they did it since im going that route also with the ls1 brake setup as well.
Old Oct 28, 2011 | 04:43 PM
fast377's Avatar
Car: 91 Z28
Transmission: t-56
It's the same as what I posted. CTS-V and 5th gen uses the same caliper (except one has the v logo and the other says camaro...same brembo casting though).
Old Oct 28, 2011 | 05:39 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Yeah i know the calipers are the same but i know the rotors are different but just found out ima just go with z06 rotors and sell my 5th gen stock rotors
Old Oct 29, 2011 | 07:49 AM
fast377's Avatar
Car: 91 Z28
Transmission: t-56
Only difference in the rotors is the Z06 are drilled and the SS rotors need the center bore enlarged.
Old Oct 29, 2011 | 02:31 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
So i will be able to use the ss rotors then if i just bore the center hole?
Old Oct 29, 2011 | 02:35 PM
fast377's Avatar
Car: 91 Z28
Transmission: t-56
Yes sir
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
i will post of pics of my stock rear brakes to ls1 brakes wednesday... swapping the entire rear over...
Old Oct 29, 2011 | 02:41 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Originally Posted by fast377
Yes sir
Oh ok thanks since in another thread they told me the offset is different as well so that left me thinking if i could use it.
Old Oct 29, 2011 | 02:45 PM
fast377's Avatar
Car: 91 Z28
Transmission: t-56
Ed's kit uses the SS calipers and the SS rotors with the center bore enlarged. There was a thread on here about it a while ago. I'll see if I can find it.
Old Oct 29, 2011 | 02:50 PM
fast377's Avatar
Car: 91 Z28
Transmission: t-56
Here it is: https://www.thirdgen.org/forums/brak...embos-3rd.html
Old Oct 29, 2011 | 03:02 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Alright thanks ill post pics of mine as soon as i get a hub made or when i buy one.
Old Nov 16, 2011 | 10:18 PM
Bradlyj8Z28's Avatar
Car: 1991 Camaro Z28
Engine: 2002 SS LS1
Transmission: 6 speed
Axle/Gears: Auburn 3.42
KORE3 C6 Z06 brake kit, 14inch rotors with 6 piston calipers
Old Nov 17, 2011 | 10:49 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
front upgrading of my upgrade
rear upgrade of my upgrade
my 70 Formula getting a upgrade as well
Old Nov 18, 2011 | 02:06 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Nice pics you guys keep them coming
Old Nov 19, 2011 | 04:39 PM
Ed1LE's Avatar
Car: 91 Firebird 'vert, 91 Formula
Engine: 5.7, 5.0
Transmission: T56, T5
Axle/Gears: Auburn w/ 3.73's, 3.42
C5 fronts.
Old Nov 20, 2011 | 11:15 PM
skiroulertx447's Avatar
Car: 86 Z28
Axle/Gears: 3.42 posi
not the brakes themselves, but but definitely improved them!
Old Nov 21, 2011 | 01:02 AM
mike_c's Avatar
Car: 1989 Trans Am GTA
Axle/Gears: 9 Bolt 3.70
LS1 fronts with d/s rotors, EBC red stuff pads and stainless lines. I couldn't be happier with this setup
Old Nov 23, 2011 | 08:51 PM
Realmac4's Avatar
Car: 1991 Z-28/ '94 Impala SS
Engine: 355 TPI/ 350 LT-1
Transmission: T-56 in both
Axle/Gears: 3.73 / 4.56
Modded stock spindle for 1-LE
EB Miller alloy hub
13 in C4 HD rotor
C4 caliper (same as 1-LE but with the line fitting on the side instead of the bottom)
Rear drum to 12 in LS car disc
Old Mar 15, 2012 | 01:39 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
test fit of the 19s with 5th gen brakes they look small haha
Old Mar 15, 2012 | 01:40 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Sorry for the bad cellphone quality pic
Old Mar 15, 2012 | 11:55 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
My new LS1 brakes, thanks to mw66nova 's hard work and help to get it done... unfortuantely garbage cell phone cam for the first pic:
Old Apr 1, 2012 | 01:17 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Subscribed!
Too many good ideas here not to latch on!
Old Apr 1, 2012 | 03:48 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
im not finished yet, but here my current upgrade. Baer 6s calipers and 14" pcs rotors, Kore3 aluminum hubs ect. all the goodies
Old Apr 1, 2012 | 04:38 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Now those brakes are SWEEET!
Old Apr 1, 2012 | 04:39 PM
88fastgta's Avatar
not the greatest pic but ls1 brakes in the rear.... just barely clear the stock rims.... stopping power has greatly improved..
Old Apr 1, 2012 | 05:17 PM
pg29's Avatar
Car: 88 GTA
How much did that setup cost you? Those look like they'd make great track day brakes.
Old Apr 3, 2012 | 04:14 PM
91 1LE's Avatar
Car: '91 1LE
Engine: 377 w/Stealthram
Axle/Gears: 3.42 Torsen
Baer 6S calipers with 14" 2pc rotors.
Old Apr 3, 2012 | 04:30 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
maybe some big brakes are next for me hmmm..stuff looks great guys!
Old May 19, 2012 | 01:46 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
Here are a few pics of my LS1 brake upgrade
The LS1 calipers dwarf the stockers!
Last pic shows where I had to grind off some of the stock steering stop mount on the inside of the stop mount. I also had to grind off some of the banjo bolt that holds the brake line to the caliper....now the spindle assembly hits the steering stop like it is supposed to.
Old May 20, 2012 | 04:51 PM
bigdavesiroc's Avatar
Car: 87 iroc
Engine: 410 sbc
Transmission: tremec 3550
Axle/Gears: 30 spline 3.73
i'm looking at doing the 2010 ss brakes on my car with 18" rims...any fitment issues and are you guys having to upgrade the master cylinder/booster?
Old May 20, 2012 | 07:21 PM
L695speed's Avatar
Car: '88 Trans Am GTA; '84 Trans Am
Engine: L98 350TPI; 5.3 LSx built
Transmission: N/A; T56
Axle/Gears: 3.70 9 bolt; 3.73 10 bolt
Nothing too special and not 100% done yet, but LS1s on Formula 16" concave wheels. Spindles were done by bigbrakeupgrade.com, rest of the parts were sourced from rock auto or Amazon.
One.
Two.
Three.
Still need pads and hard lines, not to mention rear PBR calipers and pads and lines.
Old May 21, 2012 | 12:35 AM
IROCtheRoad's Avatar
Car: 84 Z28, '15 Colorado
Engine: L69
Transmission: A4
Here's a few of my 1LE upgrades. It's not big, but it's as big as I can go :-)
Old May 24, 2012 | 10:34 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
ctsv version one brembo brakes 14" rotor and with my old wheels . car weighs 3300 lbs.
ls1 t56 a/c , full 4th gen interior, 18" wheels all around they get the job done.
i was looking into the 6piston newer design cuz it looks pimp but well see
Old May 26, 2012 | 02:35 PM
rlewi771's Avatar
Car: 86 IROC
Engine: 350 ZZ4
Transmission: TKO-600
Wilwood 4 piston FSL kit through flynbyeperformance.
Old May 26, 2012 | 02:45 PM
Twin_Turbo's Avatar
Slapped this together quickly to go on my gray IROC, the stock brakes are junk..pads are worn, good excuse to swap it all (and the stock brakes look silly behind 19s), it's going on there on Monday.
Old May 28, 2012 | 02:29 AM
  #42
J-RoKz's Avatar
Car: 1989 iRoC-Z, 1991 Rs
Engine: L98, L03,Lsx swap soon
Axle/Gears: G92 3.27,10 bolt 3.23
sexy what is needed to do the c6 z06 brake swap? i currently have the the c6 z51
Old May 28, 2012 | 02:38 PM
  #43
Twin_Turbo's Avatar
z06 calipers, pads, clips, pins and discs. Bolts up to std. C5/6 conversion brackets
Old May 29, 2012 | 07:42 AM
  #44
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Who's changing out their master/boosters for these? I have LS1 rears, C5 13" fronts and brakes still suck...I have an issue somewhere but havent gotten around to checking for it. Thinking master needs bench bled but my booster may not be 100% anymore. I cant tell.
18" C6 wheels. I need more brake to fill that gap Thinking CTSV 14" soon
Old May 31, 2012 | 12:50 PM
  #45
87350IROC's Avatar
Car: 87' IROC
Or Gen II CTS-V would be even better. Fills out an 18" pretty nice with the Z06 rotor. Or you could even fit the 14.66" CTS-V rotor inside an 18".
Old Jun 17, 2012 | 05:17 AM
  #46
J-RoKz's Avatar
[IMG][/IMG]
thanks c6 z06 swap coming soon
Old Jun 17, 2012 | 08:40 AM
  #47
400 hp's Avatar
Car: 86 z28
Engine: 355 113 heads ported HSR hot cam
Transmission: th350
Axle/Gears: 7.5 342
Ls1 front and rear brake + new wheels..
Attached Thumbnails Post your brake upgrade pics here!-wheels-roh-001-medium   Post your brake upgrade pics here!-wheels-roh-002-medium   Post your brake upgrade pics here!-big-brakes-002-medium
Old Jun 17, 2012 | 08:55 AM
  #48
GTA matt's Avatar
Car: 1990 GTA/1989 Iroc
Engine: L98/383
Transmission: 700r4/t56 magnum
Axle/Gears: 9"
Don't think I've seen any drag brake setups here, so I'll post mine up. Wilwood dynalite, 4 piston calipers, front and rear.
Front rotors and hubs assembled and safety wired.
Spindle meet caliper and rotor
I didn't weigh the entire assembly before, but you can get the idea. The entire new assembly is lighter then just the old caliper and rotor.
And mounted up
Rerouting lines away from headers and any heat
Waiting on my rear end housing so the rear brakes aren't mounted yet, just assembled the rotors
Old Jul 11, 2012 | 08:35 AM
  #49
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
Subscribed.
Old Jul 11, 2012 | 11:27 AM
  #50
lozantius82's Avatar
Car: 89 Camaro Iroc Z
Transmission: MK6 World Class T5
Axle/Gears: 9 bolt had 3.45's, now 3.27 gears
Are those the 1LE rotors? I want to do the swap on my 89 but i want to keep my stock wheels.
