ls1 rear end clear gta rims
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
hey i just want to make sure about this... im getting a ls1 rear end with ls1 brakes and i was wondering do they clear the rear gta rims..... thanks in advance...
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: ls1 rear end clear gta rims
i have the gta wheels on my stock 10bolt with the ls1 brakes and they clear just fine. aside from moving your wheels out a bit further, there should be no clearance issues
ok thank you very much..... i thought i needed spacers for them to fit...
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Been awhile since I looked into doing this, since I ended up going to 17" aftermarket wheels instead of staying with my crosslaces anyways, but I seem to recall that with the deeper BS on rear crosslaces, they would hit. But front crosslaces fit them better or by using the slip-on factory 16mm (iirc) to space out the rear BS wheels.
damn thats what i figured..... where can i get some spacers... .eventually i want to run all four fronts... but i need better brakes because the lt1 brakes suck...
Car: 86 Trans Am
they fit, no problem, im using them..... want pictures?
ls1 front brakes wont clear the wheels, and you may need spacers there.
I believe u.... it was the previous comment that made me think... by if ur running them then I'm going to save my pennies.. did you notice an improvement in braking compared to stock brakes....
Car: 86 Trans Am
i have them on my 86 also and they work quite well. I have adjustable prop valves on both cars, and once you get them tuned in, they are great
Thats great to hear.. eventually I want to get ls1 front brakes as well... my stopping power sucks big time right now...
Car: 1989 Trans Am GTA
Transmission: M28 T56
lol.... thats good to know i was about to get some gta front rims to put on my back....
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Car: '89 GTA 9,000 MILES
Axle/Gears: 3.27 9 bolt
Thanks. I want to be crystal clear on this though.............
Front GTA rims will clear the LS1 front brakes but not the rear GTA
wheels ??? Correct ?
If this is the case, what exactly would one ask or search for on these factory spacers...I mean exactly what were they called other than spacers and what years were they on ?
Thanks...........
Thanks...........
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Will these be enough to push the rears out enough to clear the LS1 brakes on the front ????
Car: 92 Firebird
Engine: 4.8 LR4
The offset on the wheel is for the steering arm on the spindle. With my brake package my wheels were pushed out further than the rear wheel offset so I will run 4 rears all the way around.
GTA wheels, whether front or rear, may not clear front LS1 brakes. You may need a spacer as said several times. The wheel "face" may come in contact with the caliper
Have you read through the sticky? I think this combo was covered in there
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
3rdgenparts
Aug 6, 2015 09:03 AM
