10 to 10.5 inch front disk swap
Old Nov 1, 2011 | 01:09 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Am I correct in assuming the calipers for the 10 and 10.5 inch front disc are different? To swap to the larger does the spindle part need to be swapped too?
Old Nov 1, 2011 | 06:31 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 10 to 10.5 inch front disk swap
With the exception of the 1LE, all thirdgens are equipped with 10.5" rotors and iron Delco-Moraine calipers.
JamesC
Old Nov 1, 2011 | 10:13 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
So I discovered when I measured again! Oh well.
customblackbird
Aug 15, 2021 10:16 PM
kyleb24
Aug 15, 2015 08:24 AM
TA8487
Aug 11, 2015 09:02 PM
wruiz
Aug 11, 2015 02:59 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
