Proportioning Valve Wire
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
Hey guys, never noticed this until tonight when I was checking my fluid level, but there is a single tan wire that goes to what looks like some sort of sensor in the top of proportioning valve. What function does this serve?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Proportioning Valve Wire
Pressure differential switch to light the brake warning lamp on the dash.
Car: 1985 Z28
Car: 1985 Z28
Under what circumstances would this trigger the light?
Engine: 383 Carb
Transmission: 4L60
When pressure in the front circuit is substantially higher than the rear, or vice versa, such as you'd have with leaking or broken lines.
Car: 1985 Z28
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Yes, when working properly, the wire sends a ground to the brake warning light in the dash, completing the circuit. Ground it and the dash light should come on (with key on).
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
And if light is on(for example after bleeding brakes)you can reset that pd switch by pressing pedal real hard.
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
This has piqued my interest - my switch has never been connected due to the lack of a connector/pigtail - the good ol boys PO's must have made off with it years ago. Tan wire just hangs there, tucked up out of the way.
Not of huge importance, but anyone know where to get one or at least have a pic?
Same style connector as on the head-mounted fan switch, knock sensor, etc.
From two different cars, the first is my 92 V6 with the prop valve still installed and in use, The second is on my 89, which has an adjustable prop valve to the rears, and an LS1 master cylinder with level switch that I use instead, thus the other wire coming out of the loom.
Every GM car had this same thing, for a couple of decades.
Just go to the junkyard and look at any of em from the late 70s up until the early 90s.
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Not here in Oz apparently, always wondered what it looked like. I had a cursory look thru the local wreckers a few year ago, hoped maybe 80's Commodores would have used the same thing, but no. Thanks for the pics Al.
Engine: 383 Carb
Transmission: 4L60
Even in Oz. Pretty much every GM car built since they decided dual redundant brake circuits were a good idea.
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
I'll have more than a perfunctory glance when I'm down there next, this is not something I've gotten highly motivated to fix
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Fwiw - was at the local wreckers today - all 70's-80's-90's Commodores/ Holdens I could find used a master cylinder with what looks like an integrated proportioning valve, that has a 2-pin connector for the brake switch.
Car: 1987 IROC-Z Z28 Convertible
Engine: LB9
Did you resolve your issue and have it working? It's important you know if you've lost one of the halves of your brake system. On our Camaros, the brakes have what's called a vertical split system - one circuit for the front brakes and one for the rears. Most FWD cars have a diagonal spilt system where one circuit is LF/RR and the other is RF/LR.
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Same over here, all cars on the road will have a split system of some persuasion in case of failure - it's an ADR requirement.
Haven't found/invented a pigtail for the warning light yet. I have lost brakes 3 times in my driving life - trust me you're suddenly too busy with other things, to worry about if your dash light has come on
That same style connector is used for the fan switch on the passenger side head, and for the knock sensor. Only difference should be the wire color, and a replacement will most likely have a white wire.
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
My engine wiring was butchered in an engine swap by a po - no knock or temp sensors on the block - and I've never seen one of these connectors used on any car for any purpose in the wreckers. Never come across an sbc for that matter. Afaik the sbc was not used in any car sold in this country.
Upshot is I've never come across one of these connectors in the flesh. It's not big deal, when I get around to it I'll just solder a wire onto the prop valve connector.
Engine: 4++,350 & 305 CIs
Kinda close in idea but they are waay different. You can't swap them on each others sending unit/switches at all..
I geuss they are different, though similar looking. They have differnt part numbers. I tried to find the brake connector part number for comparison, but no luck, thought it might be the same or similar to the cooling fan switch connector since all each of them does is route a ground - one to light a bulb and one to energize a relay.
1992 Trans Am
May 10, 2023 07:19 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
