size of rear brake line fittings?
Old Dec 5, 2011 | 11:59 AM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Ok, I am trying to figure out the size of the brake line fittings on the hard line that run along the rear axle from drum to drum. I will be doing a rear swap soon and would like the fitting sizes just incase i break one of them off. I believe the rear line along the axle is 3/16 inch line? and the fitting that goes into each wheel is 10 mm X 1.0 ? Is that correct? how about the fitting that goes into the T-line? It seems that one is a bigger fitting. Maybe a 12 mm X 1.0 ? Need some help here.
Old Dec 5, 2011 | 07:04 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: size of rear brake line fittings?
Both ends of the hardlines on the axle are 10mm 1.0. The line is 4.75mm but 3/16 will work just fine.
Reddeath210
Oct 6, 2015 08:20 AM
kyleb24
Aug 15, 2015 08:24 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Leggman1
Aug 6, 2015 04:15 AM
