E-brake doesn't work
Old Dec 18, 2011 | 11:31 PM
Termanalor117's Avatar
Car: 1991 Pontiac Firebird Trans Am
Engine: 1987 Chevy 355 TPI Mild Cam
Transmission: 5-Speed T-5 WC
Hi,
Just bought a 1991 Pontiac Firebird GTA and the e-brake doesn't work. I can pull the lever and the light comes on but on brakes? I had a friend look at the cable and said its fine but not sure if he is right. Any other ideas or thoughts?
Old Dec 19, 2011 | 03:49 AM
MAC_87's Avatar
Car: 1987 IROC-Z
Engine: 5.7L
Re: E-brake doesn't work
with disc brakes, theres 3 cables, one from ebrake to the back of the car, then another cable on the right, another on the left.- Picture an upsidedown Y; I just replaced mine the other day, $20 for right side, $30 for left. main ebrake line was fine. Make sure they're fastened to the back brakes correctly; through the springs. and make sure the ebrake is fastened correctly from the ebrake line to the other two.(I'm not sure if its the same with drum brakes)
Old Dec 19, 2011 | 07:42 PM
Ok, so the cables are fine its the part in the center console. The lever goes up and everything but the brakes don't actually engage. There is some other lever or something in there you can push down and it sometimes works that way but otherwise im still stumped. Any other help?
Old Dec 19, 2011 | 11:13 PM
MAC_87's Avatar
Car: 1987 IROC-Z
Engine: 5.7L
jack the rear of the car up (+jack stands) and make sure your rear brakes work, accelerate and apply the brakes. Please use EXTREME CAUTION. - make sure youre calipers + pads work correctly. If all your lines are in tact and connected correctly then you may have bad pistons in the calipers, or possibly bad pads.
Old Dec 20, 2011 | 08:37 AM
Very good idea, thanks!
Old Dec 20, 2011 | 10:05 PM
tylercamaro's Avatar
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
is the cable connected to the brakes and to the actual ebrake handle
Old Dec 20, 2011 | 10:31 PM
Well I did some looking into it, probably should of done it at first but the cables are all good just the Y point where the main cable splits off was only connected to one of the brakes. I just needed to put that back in place, adjust the cable tension and it was good to go. Thanks though!
Frozer!!!
Jan 19, 2024 04:55 PM
Wylecoyote08
Nov 6, 2015 03:46 PM
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
