4th gen Proportioning valve
Car: 92 Firebird, 91 Trans Am
Engine: L31 with HSR, LB9
Transmission: 700R4, 700R4
Axle/Gears: '99 10 bolt 3.90, '01 10 bolt 3.42
I'm about to start a 4th gen disc rear swap. I currently have drum breaks and I'm wondering how important it is to swap an ajustable pro valve or a 4th gen pro valve in. I heard it was necessary but I wanted second opinions because it seemed like it would be impotrtant for the brakes to receive the correct amount of pressure.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 4th gen Proportioning valve
https://www.thirdgen.org/forums/tran...ve-91-z28.html
JamesC
So I need this one even though it says 82-89? http://www.flynbye.com/catalog/i40.html
http://www.flynbye.com/catalog/i172.html
Or GMPartsDirect, GM 10164112.
Have a laugh at the above from GMPartsDirect:
https://www.thirdgen.org/forums/brak...2-1le-j65.html
JamesC
JamesC
Thanks for the help man. I take it the 1LE is the best valve to use even if they aren't 1LE brakes? or are all 4th gens 1LE?
ambainb
Apr 25, 2016 09:21 PM
