87 Iron Rear Calipers, Brake Line Question
Old Jan 7, 2012 | 11:28 PM
insomniac's Avatar
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
I am swapping in a 9 bolt 3.45 with the rear calipers going from a drum setup.
How are the lines routed, i got a soft line into the right rear caliper but how does the left go? There is no soft line for the left rear.
also why the hell do the pads sit a little loose in the calipers?
Old Jan 8, 2012 | 07:20 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 87 Iron Rear Calipers, Brake Line Question
The above is correct: flex line on the pass side, hard line on the driver's side.
JamesC
Old Jan 8, 2012 | 08:58 AM
insomniac's Avatar
Engine: 5.7 L98
JamesC
so just a hard line directy from the soft center brake line to the caliper?
Old Jan 8, 2012 | 09:57 AM
L695speed's Avatar
Car: '88 Trans Am GTA; '84 Trans Am
Engine: L98 350TPI; 5.3 LSx built
Transmission: N/A; T56
Axle/Gears: 3.70 9 bolt; 3.73 10 bolt
Yes that is correct for the Iron rear discs. You should be able to get it from one of the brake line suppliers already bent. I believe thirdgen ranch will supply the rear hardlines only if thats all you need.
Old Jan 8, 2012 | 09:58 AM
JamesC's Avatar
Yes.
JamesC
Old Jan 8, 2012 | 01:12 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
I must have had an oddball set then. My rear end on my 89 is from a 1983 Trans Am and had hard lines to both calipers prior to my LS1 rear disc swap. The '83 brake lines were purchased from In-Line Tubes http://www.inlinetube.com/Preformed%.../CC-CAT-08.htm
Old Jan 8, 2012 | 02:17 PM
JamesC's Avatar
Hard lines to both sides in 82-83 are fairly common, I think. Of course, that wouldn't have been so on a 9-bolt, which didn't arrive until 85.
JamesC
Reddeath210
Oct 6, 2015 08:20 AM
redmaroz
Aug 16, 2015 11:40 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Leggman1
Aug 6, 2015 04:15 AM
