Mounting PBR 1LE rear brakes on LT1 brackets
Old Jan 30, 2012 | 09:47 AM
89mulletbird's Avatar
Car: 89 GTA
Engine: 6.0L Procharged
Axle/Gears: 4.10
I am purchasing a Strange S60 rear that comes with the LT1 backing plates. Will my '89 1LE calipers and rotors work with these backing plates? I've read that LT1 and 1LE calipers are the same.
Old Jan 30, 2012 | 09:55 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Mounting PBR 1LE rear brakes on LT1 brackets
Yes.
JamesC
Old Mar 3, 2012 | 06:03 PM
Car: 89 GTA
Axle/Gears: 4.10
I'm just mounting these up now, and there is about 1/8" gap between the backing plate and the caliper. I'll need to shim this for some reason, I wonder what isn't correct with my setup?
S60 rear with LT1 backing plates
1LE calipers
1LE rotors
Old Mar 3, 2012 | 08:32 PM
91 1LE's Avatar
Car: '91 1LE
Engine: 377 w/Stealthram
Axle/Gears: 3.42 Torsen
You need to center the caliper mounting bracket over the rotor. All of them are off a little either way. I used thin washers between the axle bracket and the caliper bracket. If you don't center it the rotor can rub the bracket on turns and cause a very wierd ringing noise. Ask me how I know...
Old Mar 3, 2012 | 08:46 PM
JamesC's Avatar
OE-type shims can be seen in the following link:
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
JamesC
Old Mar 3, 2012 | 10:01 PM
Car: 89 GTA
Axle/Gears: 4.10
Yeah in order to center it I had to use two M12 washers. I'll follow up with Strange Engineering to see why I had to do this with their LT1 backing plates.
Old Mar 4, 2012 | 07:29 AM
JamesC's Avatar
I'm uncertain about the LT1's, but OE shims were fairly common on 90-92 ten bolts. Apparently nine-bolts didn't have them.
JamesC
Old Mar 4, 2012 | 09:40 PM
91 1LE's Avatar
Car: '91 1LE
JamesC
Probably has something to do with C-clips versus bolt-in axles.
Vintageracer
Jan 10, 2020 05:33 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Eric-86sc
Apr 3, 2016 03:52 PM
kyleb24
Aug 15, 2015 08:24 AM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
