LS1 front brakes,spindle bracket thickness?
Old Jan 31, 2012 | 01:15 PM
z 28 jari's Avatar
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
Hi,
I need to reduce bracket thickness from 10mm(~3/8") to 8mm(~5/16") that I got rotor middle of caliper carrier.Is that 8mm bracket enough strong?
Old Jan 31, 2012 | 07:37 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Re: LS1 front brakes,spindle bracket thickness?
can you put a spacer between the hub and the rotor
Old Feb 1, 2012 | 04:16 AM
z 28 jari's Avatar
Engine: 385
With current wheel setup,unfornately not.I try to minimise positive wheel offset so the front wheel stays inside front fender.At that reason from hub has been mashined 1.5mm away(from where wheel mounts)->brake disc is not centered at caliper carrier...
Frozer!!!
Jan 19, 2024 04:55 PM
sailtexas186548
Jan 19, 2016 12:21 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
86White_T/A305
Aug 17, 2015 12:16 AM
sailtexas186548
Brakes
Aug 13, 2015 11:47 AM
