Broken brake line
Old Feb 26, 2012 | 02:21 PM
zfisher89's Avatar
Car: 92 RS camaro
Engine: 5.0
Transmission: world class T5
Axle/Gears: borg warner 9 bolt
Broken brake line
i broke off a 6mm hard brake line thats heading to my rear yesterday when i pulled my rear out where can i find an buy that exact line to replace it. i looked around couldnt find anything thanks for any help
Old Feb 26, 2012 | 02:32 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Broken brake line
One of the following should be able to supply your needs:
http://www.finelinesinc.com/
http://www.classictube.com/
http://www.inlinetube.com/
JamesC
Old Feb 26, 2012 | 04:13 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Axle/Gears: 9 Bolt, 3.27:1 Diskbrakes
ThirdgenRanch has Stainless steel lines.
Old Feb 26, 2012 | 04:15 PM
zfisher89's Avatar
Car: 92 RS camaro
Engine: 5.0
i cant seem to find just the one line everthing ive seen are kits
Old Feb 26, 2012 | 04:17 PM
Go to the parts store and buy one... even AZ and Advance and such have sticks of brake line in about 10" length increments with the flare nuts on them.
Old Feb 26, 2012 | 04:52 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
IIRC, I used In-Line Tubes for my rear lines. I ran into the same problem of finding only kits on the website, so I called them up and special ordered just the rear lines I needed over the phone. I would imagine that the other sites JamesC linked would do the same.
Old Feb 26, 2012 | 05:45 PM
zfisher89's Avatar
Car: 92 RS camaro
Engine: 5.0
thanks i may have to try that
Old Feb 28, 2012 | 06:44 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
i grabbed mine from fine lines, part number FIN8601OM is the front to rear line. but thirdgen ranch carries them now too and they're a good site sponsor, price is pretty close
Old Feb 28, 2012 | 09:34 PM
zfisher89's Avatar
Car: 92 RS camaro
Engine: 5.0
how bad is the install
Old Feb 29, 2012 | 07:22 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
they're usually pretty dead on for the originals, so installation's not bad. just remove the mounting screws for the lines (shared with the fuel and evap lines on the driver side) and remove. i found it was much easier to start from the front of the vehicle (from the engine bay) with it off the ground and pull through from underneath. lots more stuff in the engine bay to fight with than under the rest of the car
Old Feb 29, 2012 | 12:38 PM
Thirdgen Ranch's Avatar
Former Sponsor
Car: Too many
Yes, we have the lines available on our site. Our lines are CNC bent to be exactly like your originals. They are the highest quality lines avaialble. We have them in original steel or stainless.
Old Feb 29, 2012 | 02:07 PM
zfisher89's Avatar
Car: 92 RS camaro
Engine: 5.0
Thanks for the info I'll be ordering soon.
Reddeath210
Oct 6, 2015 08:20 AM
Warlocksirix
Sep 3, 2015 12:26 PM
Nj1987
Aug 19, 2015 08:26 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
