Forth gen wheels and brakes.
Old Mar 14, 2012 | 07:47 PM
wht96's Avatar
Sorry guys I've been trying to narrow this down. I'm going to be running 4th gen wheels and I'm also planning the ls1 brake swap... My question is will 1.5 wheel spacers work with this setup? I wont be running the new brakes for probably another month or to at the earliest so will the 1.5 also work without looking completely terrible until I put the brakes on?
Old Mar 15, 2012 | 01:52 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: Forth gen wheels and brakes.
The only difference in offset the brakes will make is the thickness of the floating rotor over the hub. Maybe 1/4 inch at most?
Old Mar 15, 2012 | 07:51 PM
Jstcrzyengh's Avatar
Car: 1988 Camaro Convertible
Engine: 355
I asked Scott over at BigBrakeUpggrade.com that exact question, here is what he said (Sorry Scott if this isnt cool)
Im going to be running 17 upfront and 18 in the back stock C5 "Y2k" corvette wheels with a 4th gen rear and I was wondering if I would just run the same 2.25" adapters as I would normally upfront with either your LS1 or C5 kit. I just dont want to add much larger brakes only to weaken the wheels because the spindles and all are modified with adapters.
Thanks (especially if youve been asked that a hundred times before)
Hi James,
Good question, regardless of what wheels are used, the same modifications are required. The wheel spacers you have will work just as they are now. The kit (c5 or ls1) will move the wheels out by .300 of an inch per side. Normally I hear guys running 2 inch spacers, I suggest to run 1.75 spacers with the kits but your wheels may have a deeper offset if you have to run 2.25. I would go down to a 2 inch in your case. Hope that helps!
Have a good day!
Scott
Hope that helps! Im going to run 2" upfront and Im picking up Scott's C5 kit.
Old Mar 15, 2012 | 08:34 PM
wht96's Avatar
Thank you allot that was exactly what I was looking for! Do your corvette wheels have a larger offset then fourth gen wheels? I don't know why I thought they were the same? If I'm not mistaken you need 2" for fourth gen cars
Old Mar 15, 2012 | 11:17 PM
Engine: 355
Im pretty sure 2.25" is the norm for the Y2k's (from what I recall), but I have a lot of issues with rubbing. Making a right hand turn is not fun.
Terrell351
Jun 13, 2021 01:13 PM
sailtexas186548
Jan 19, 2016 12:21 PM
Omega
Oct 1, 2015 02:20 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
