? ABOUT IRON REAR BRACKS ON 92
Car: 92 camaro rs
Engine: 3.4v6 sc
Axle/Gears: 9 bolt 3.73s
ok i have a rear 9 bolt with disc, my 10 bolt is shot making bad funny sounds, the 9 bolt i have is a 2.77 sucky gearing i know, with the iron rear disc,my ? is can i just get bye with hooking it up im not doing any racing with the car any time soon street use only ,its a 1992 rs v6 camaro , can i make it work till i find a pbr set up kinda low on money two i have drum on the back now ,mostly a show car and to get to work
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: ? ABOUT IRON REAR BRACKS ON 92
JamesC
Car: 92 camaro rs
Engine: 3.4v6 sc
im not looking for a vett killer brake set up just somthing to get me bye and i have the tunn ebrake cables
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
easiest route is probably to just repair the 10bolt drum
rear in the car instead of converting to the 9bolt-
take the cover off the 10bolt and see what the trouble is
-especially check for a loose pinion nut,bad or loose
carrier bearings,chipped teeth(often caused by loose
pinion nut)and metal in the oil.
junkcltr
Aug 2, 2019 11:12 PM
ambainb
Apr 25, 2016 09:21 PM
sailtexas186548
Jan 19, 2016 12:21 PM
