Which master cylinder and P/V for the 90-92 1LE?
Old Apr 18, 2012 | 10:29 PM
CamaroX84's Avatar
Several years ago, I did several mods to my 84 Camaro (engine swap, suspension, trans, rear end, etc.). I also swapped out my stock brakes for a 1LE setup from a 92 (I believe) Police Package Camaro.
The problem is, since I did that, my brakes have really been poor. Very weak stopping power. My vacuum is fairly low due to the cam, so I installed a vacuum reservoir...didn't really help. The car sat for quite some time so I am just now trying to get it back up and going again.
I can't for the life of me remember if I swapped out the master cylinder and proportioning valve. I'm assuming from the amount of threads on this topic that the master cylinder and P/V are different for this setup. I'm also assuming that it would make a big difference on brake performance.
Long story short, what part numbers should I look for to ensure I have the right ones for my setup?
Thanks in advance.
Old Apr 19, 2012 | 06:35 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Which master cylinder and P/V for the 90-92 1LE?
Hopefully, your 84 combination valve is metric. If so, you'll need the first-design valve, which is available below:
http://www.flynbye.com/catalog/i40.html
More about the valve and master can be found in the following link (BTW, I used the J50 drum master and have been well satisfied):
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Apr 23, 2012 | 11:10 PM
CamaroX84's Avatar
Thanks for the reply. Hopefully I will have time to work on it some this week.
Fireslash
Apr 11, 2016 06:43 PM
jaridjohn
Oct 5, 2015 07:01 AM
meeklay812
Oct 1, 2015 03:46 PM
usafirebird
Sep 29, 2015 11:58 PM
