Huge calipers found in back of thirdgen? Can anyone identify?
Old May 19, 2012 | 11:53 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Found these calipers near brand new (cept rust from humidity) in the back of a RS thirdgen in a Junk Yard. Did a search for the number cast into the caliper but had zilch results for that number.
Can anyone identify them? The pistons were freaking HUGE! I didn't have anything I could use as a comparison for size and no ruler with me at the JY.
I don't plan on using them as I'll likely being doing LS1 brakes, its more of a curiosity to me. Calipers still had all of caps covering important bits. Obviously never used too.
http://home.comcast.net/~thirdgen89g.../caliper01.jpg
http://home.comcast.net/~thirdgen89g.../caliper02.jpg
Old May 20, 2012 | 03:35 AM
87350IROC's Avatar
Car: 87' IROC
Re: Huge calipers found in back of thirdgen? Can anyone identify?
Those look alot like the OEM front calipers. Any reason to believe they aren't?
Old May 20, 2012 | 05:48 AM
Jeffs82TA's Avatar
airbus A380 calipers
Old May 20, 2012 | 06:10 AM
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
Old May 20, 2012 | 06:45 AM
The piston just seems extraordinarily large.
Lol.
Old May 20, 2012 | 09:30 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
They look like a GM metric front caliper. Nothing special.
Old May 20, 2012 | 02:43 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Measure the OD of the piston where it contacts the pad. If 2-3/8" then it is the standard front metric caliper. If closer to 3", then likely they are the older D52 front caliper.
RBob.
sailtexas186548
Jan 19, 2016 12:21 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
Linson
Aug 21, 2015 02:12 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
antares57
Aug 6, 2015 07:47 AM
