brake upgrade time
brake upgrade time
ima considering the front disc brake upgrade ...
if you were gonna replace the discs calipers pads and hoses ...
how would you do it ? which kit is the best way to go ?
i appreciate yer input on this ...
with mechanics like you all around i canT go wrong
part #s are welcome ... going on my 1991 Z28 5.7
ima going with R15s 17x9.5 so as i investigate i understand that
i can go with C5 front discs ... although ima trying to keep the cost down
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Re: brake upgrade time
You have a lot of options from GM, Wilwood, Baer, and others. A 17" wheel will allow a 13" rotor and a radial caliper without much problem - but measure to make sure!
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
LS1 Camaro brakes are the best bang for buck by FARRRRR and can be done under $300. Hell, cheaper than that depending on how mechanical you are.
Ebay is a good place to buy. I did and hooked up a hell of a deal for fronts and rears. Here's a quick search:
http://www.ebay.com/itm/02-Camaro-Tr...item19c93177ea
http://www.ebay.com/itm/98-02-Camaro...item45f8c896bf
Car: '91 LS6/T56/9"
Engine: LS6
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
yeah for normal street use, you cant beat ls1 brakes price, and performance. If you plan on doing some auto crossing or any thing where you will need to be one the brakes more I would suggest c5. I went with c4 hd's for my car, but that was mainly because they fit the theme of my car otherwise I would have went c5.
LS1 package
http://www.bigbrakeupgrade.com/products.htm
C5 package
http://www.bigbrakeupgrade.com/products2.htm
here's a good link too
https://www.thirdgen.org/forums/faq-...s1-brakes.html
Engine: 4++,350 & 305 CIs
We are in the middle of a C4 HD swap on a 92 formula350 right now. Im thinking he has 500$ ish in it.
I like the look of the C4,1LE PBR caliper because it "looks" more period correct than the LS caliper.
Car: 1992 Camaro RS 25th Anniversary
Engine: Stock 305 TBI, LT1 soon.
Transmission: V6 NWC T5 by choice
Axle/Gears: Zexel Torsen LSD with 3.23's
I pieced together my front C5/GTO and rear LS1 setup for under a 1k. I have 17" wheels and the brakes fit w/o incident.
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
does the C4 HD system use a larger rotor? Because i have 1LE's already, looking to just use a larger rotor with the correct caliper brackets to move out the caliper to accept the larger rotor... any info??
I forgot you will also need to get some hubs made, to accept the c4hd rotors
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
Ed Miller (flynbye performance) lost his machinist, due to a heart attack. I wonder if he's still going to be taking orders or what the deal is. I tried calling, and the number doesn't work.
It is always sad when a great person is lost. From what I read, Mr. Sullivan was a good and honorable man. I salute his service to our country, me being a fellow veteran and proud American, and my prayers go out to his family and friends.
... got an email saying those guys have enough work right now ...
looks like LS1 is the way to go since there aint no other way to go
C5s are too big i wanna run my stock wheels in the winter...
wish i could do the C4s tho ...
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
If you want a little extra flair to your brakes, you can run the LS1 brackets and carriers and use C5 calipers. They will bolt right up and work on the LS1 rotors from what I understand. Everything lines up, and they will fit under stock 16 inch wheels. C5 calipers with C5 brackets and C5 rotors etc will not fit in stock 16 inch wheels. To fit it in the factory 16's, you HAVE to use LS1 rotors and caliper carriers. But either way, the point is if you just dont want plain jane LS1 calipers, that can be fixed, very easily.
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
why the need for ls1 setup, whats wrong with just getting new hardware for your calipers and some drilled slotted rotors and ceramic, or even carbon pads, you can get all that stuff on summit, order it all together and it will be less then the ls1 upgrade someone said 500 for the ls1 well
two cross drilled slotted rotors from summit 55 a piece 110
hawk performance carbon pads 55
caliper hardware kit from autozone 5 bucks, get two and its 10
new bolts/ guide pins 18 dollars for all 4 that you need
if necessary two new calipers 28 dollars
add in some of the cerami glyde goop and your still only in it for like 230 bucks and most of your parts are LIFETIME WARRANTIED, if it brakes, ya get new ones.....FREEEEEE
anyways just my 2 cents
Car: 1992 Chevrolet Camaro Z28
Engine: 5.7 TPI
Transmission: 700R4 Overdrive Automatic
Axle/Gears: 3.23:1 Positraction
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Transmission: 5spd
i understand that but i've never had a problem with my stock brakes, and yes i have street raced and not experienced brake fade, i get using ls1 brakes if you were into autocross or drove the car hard regularly but for a dd or a weekend toy the stock ones are fine, if your brakes arent fine then you need to check everything out, just saying
R15s oughTa shOw a LiL PC
.As someone who's run the old J65 system and switched to a newer (1LE) system, I can honestly say that I'd never consider a return to the old. That said, each to his own.
JamesC
Car: 83 z28
Engine: boat anchor 305 (ex CFI)
Axle/Gears: 3.23 10 bolt
I agree with James, anything is better than what's on the car now. And with the current prices to swap to ls1 bits, unless the car see's track time that setup is about the best thing going.
Cheers!
Cheers!
Car: check
Engine: check
Transmission: check
I've faded the stock factory cast iron brakes in rush hour traffic. And by stock, I mean stock: rotors, calipers, pads, lines. For some odd reason those brakes are no longer on the car.
RBob.
RBob.
looks like ima going with Koni's for $596.92 per set at www.ajusa.com
my LS1 setup will be here tomorrow ... the Z is too nice to hold back for pricing ...
sailtexas186548
Jan 19, 2016 12:21 PM
"IF I HAVE TO"
