convert combo valve to disk?
Old Jun 16, 2012 | 04:52 PM
WhiteBlaze's Avatar
Car: 1984 Firebird
Axle/Gears: 3.42's
I've spent a lot of time searching but can not get a clear answer. My Firebird originally came with drum brakes which I changed to LS1 disks on all 4 corners. Some posts state that a new combo valve is needed while others state that just changing the spring inside is all that is needed. To complicate matters I've read that drum valves leave slight residual pressure to keep the brake cylinder cups flaired. So can someone please tell me what needs to be done? Thanks!
Old Jun 17, 2012 | 02:50 PM
WhiteBlaze's Avatar
Car: 1984 Firebird
Axle/Gears: 3.42's
Re: convert combo valve to disk?
73 views.... anyone?
Old Jun 20, 2012 | 08:30 PM
WhiteBlaze's Avatar
Car: 1984 Firebird
Axle/Gears: 3.42's
If I purchase a $100+ combo valve, and I find out later that all I had to do was replace a spring, I'm going to be a bit cranky..... just saying...
Old Jun 21, 2012 | 01:09 PM
gcpoland's Avatar
Car: 86 MCSS-87 Z28
Transmission: Auto OD-5spd
Axle/Gears: 3.73 both cars
Replace the spring or put a manual adjust proportional valve on rears. Try the spring, if you don't like it get and install the valve.
https://www.thirdgen.org/propvalve
1992 Trans Am
May 10, 2023 07:19 PM
1984HO
Mar 19, 2021 11:59 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
deracer
Apr 11, 2016 12:04 AM
Warlocksirix
Sep 3, 2015 12:26 PM
